Results 1 to 7 of 7
Thread: Pump setting when close to freezing
    Sep 2015
    Dallas Texas
    53
    It's going to be about 36 for the low tonight. My pump doesn't appear to have a freeze guard so my thought is ill set the timer to run all night (7 pm to 10 am) at 1725 rpm to ensure nothing freezes
    is this the best option?
    thanks
    Fiberglass pool 5300 gallons (trilogy eclipse)
    inground
    Cartridge filter
    2HP hayward ecostar sp3400vsp
    JoyfulNoise's Avatar
    May 2015
    13,193
    Re: Pump setting when close to freezing
    36F is not freezing. Even if the air temp hits 32F, it takes a lot of time for water in PVC pipes to freeze. How long will the temps remain low? If it's just a few hours overnight and then back above freezing by morning, then you hardly need any freeze protection at all.
    I would check weather.com for your local conditions and then only set the pump to run when the predicted air temp hits it's low. For me, that's often 3 or 4am before the temps dip to freezing and then they're back up by 8am.
    Matt
    Sep 2015
    Dallas Texas
    53
    Thanks. It'll only be that low for a few hours. Dallas usually gets a couple of ice storms each winter so good info for later in the year
    inground
    Cartridge filter
    Jul 2015
    Central Valley CA
    1,107
    unless you have a remote panel controlling the pump that is overriding the onboard controls it looks like it does have freeze protect. Check out page 21 of this link https://www.hayward-pool.com/pdf/manuals/EcoStar.pdf
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Sep 2015
    Dallas Texas
    53
    Thanks but it seems page has a disclaimer that it's not meant to prevent freezing
    inground
    Cartridge filter
    Isaac-1's Avatar
    SW Louisiana
    6,711
    That is most likely a don't sue us if the temperature sensor breaks type statement, which is understandable as they do break. In general I would tend to say the safest thing is to simply run the pump on low setting if the forecast calls for possible freezing temperatures, because we all know the forecast can sometimes be off by a number of degrees.
    Jul 2015
    Central Valley CA
    1,107
    Didn't notice the disclaimer, still if it will let you lower the set point to say 33F you might want to enable it could be a good safety net. I agree with Isaac, first program I created was from 4:00AM to 6:00AM since that is when it gets coldest where I live.
    Depending on what extent you want to go to an additional option is if you have a little bit of electrical aptitude you can connect a normally open 32F thermostat to one of the low voltage terminals described on page 16. When the temp drops the thermostat closes a contact and starts the pump. A mechanical example is johnson controls a19abc-24c but there are even inexpensive bimetal versions that could work albeit less accurate you can get digital versions that are super accurate but of course they would have to be powered and if not outdoor rated would need an enclosure. Point is many options out there.
