Check System: No Cell Power
Dec 4, 2015
1
Ontario/CA
I moved into a house with a pool. Last year I had purchased the variable speed pump, this spring I had it set up for salt water with the existing control. Everything was working fine and I was able to solve most "check system" lights such as "low flow" and "low salt," routine fixes. Now with the "No Cell Power" I am completely lost. Any help would be greatly appreciated. Thanks!
Common problem and easy fix. It's a burned out solder point on the back of the circuit board. You can go google "nocellpower.com" I believe is the sight ... You will also find a you tube tutorial on their fix if you google "no cell power."
Requires a low level soldering skill and an easy/rudimentary disassembly to get tot the back of the circuit board where you can get to and address the burned out solder spot.
