Results 1 to 10 of 10
Thread: Getting the balance back after RO
    Jul 2015
    Poway, CA
    58
    Some insight please.
    So the numbers before RO were:
    FC 7
    CC 0
    PH 7.5
    TA 80
    Cal 980
    CYA 120
    TDS 3507
    SWCG 2320
    After the RO:
    FC 0
    CC 0
    PH 7.12
    TA 50
    Cal 140
    CYA 10
    TDS 485
    SWCG 333
    So I added some soda ash and 2 gallons of conditioner from the calucation from the pool math. My new readings on CAL with the test kit is 425 and the TA 80 and the CYA is below 30.
    I don't want to screw up the water after the RO.
    Current number as of today.
    Temp 60F
    FC 10.5
    CC .5
    TC 11
    PH 7.0-7.2
    TA 80
    Cal 425
    CYA below 30, maybe 28
    Thank you for the help. By the way I am using the POOLMATH.
    27K Gal, IG Plaster, Hayward EcoStar Variable Pump, Pentair DE FNS Plus Filter 24, Hayward AquaRite with extended life T-CELL-15
    The Pool Cleaner Sweep
    Build in 1969
    Water From City
    TF-100 Test Kit
    JoyfulNoise's Avatar
    May 2015
    13,254
    Re: Getting the balance back after RO
    Right now your CSI is -0.40 and that's a little too low. You need to let your pH come up, 7.6 would be perfect. You can either raise it by aeration if you have a good source of aeration (like a spa spillway or waterfall) or you can use 20 Mule Team borax to raise it. While it is probably not important right away, you need to get your CYA up to probably 40ppm. Other than that, let your FC drift down to the appropriate levels found in the FC/CYA Charts and you should be good.
    Matt
    Jul 2015
    Poway, CA
    58
    do I add more conditioner?
    Build in 1969
    Water From City
    TF-100 Test Kit
    May 2015
    13,254
    Did you use liquid conditioner (CYA) or granular powdered CYA? I prefer powder as it is cheaper and more concentrated than the liquid stuff.
    You can add more granular CYA to raise it. Use the sock method as outline in pool school and determine the amount you need from PoolMath.
    Matt
    30,432
    Hold on a second.....How did your CH go from 140 to 425? You did not add any calcium, correct?
    Jul 2015
    Charter Oak, California
    273
    Sorry for to horn in......new to pool lingo.....what does RO stand for...
    It took me days to figure out PB was pool Builder not pool Boy. Picture me asking myself why the pool BOY did so much construction......
    Bob (AKA Schnozz)
    12 x 24 x 52 Intex Ultra Frame AGP, 8600 Gal; Pentair 2HP/2SP 150sqft Cartridge Filter; Hayward Through Wall Skimmer; Intex Automatic Cleaner (Fantastic); K-2006 Test Kit; Start-up 07/30/2015. First Time Pool Owner in SoCal.
    Jul 2015
    Central Valley CA
    1,109
    Reverse Osmosis (hiring a company with a truck or cart mounted filter system to remove unwanted things from water usually calcium or CYA)
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Jul 2015
    Poway, CA
    58
    140 was his digital reading and mine was with the test kit.
    30,432
    That's quite confusing on more than one level.
    Temp 60F
    FC 10.5
    CC .5
    TC 11
    PH 7.0-7.2
    TA 80
    Cal 425
    Can we assume those are test results from your (K-2006 or TF-100) testing?
    What does your water look like?
    Have you read "The ABC's of Pool Water Chemistry" up in Pool School?
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Quote Originally Posted by Imracerx View Post
    I'd go with the test kit result
    Dolphin E10 Cleaning Robot.
