Thread: Cleaning rust stains from fiberglass spa seat and floor?
    A bottle cap got into our fiberglass hot tub, and made some rust stains on the seat and bottom. Anyone have any tips on removing the stains while the water is still in tub? Looking for something that's not abrasive!
    15,000 gal fiberglass pool and spa, SWG, Pentair variable speed pump, Easy Touch controls, Aqua Cal heat pump.
    15,000 gal + Spa 500 gal, Fiberglass, SWG, Pentair variable speed pump, Pentair Easy Touch, Aqua Cal heat pump
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Re: Cleaning rust stains from fiberglass spa seat and floor?
    I suggest a rag soaked in bathtub/Fiberglas shower cleaner. I treat a hot tub much like your house bathtub, but some probably disagree
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    Try some vitamin C.
    Support the site
    Aug 2014
    Northern IL
    4,615
    Yup. Since it's localized, I would use some vitamin C tablets in a sock and scrub the stains. Should work right away.
    Thanks everyone! The Vitamin C did the trick!
    Aug 2014
    Northern IL
    4,615
    Excellent! Keep an eye out. You may get a little return where the surface was a tad more porous. Thanks for the update!!!!!
