Results 1 to 10 of 10
Thread: Pool plumbing questing
    Apr 2009
    Sarasota Florida
    143
    So I have an in ground pool with a skimmer and 3 returns. I have a barracuda g3 which can be hooked up to either the skimmer or a dedicated port for vacuum. What i suspect is a vacuum port on the side of my pool it is dead. It is about 1' below the water line right in the middle of the back wall.
    My pump only has 1 pipe coming out of the ground for suction and one going back into the ground for return.
    So what I want to know is where the heck is that port plumbed to if anywhere. Since it is an in groud why would that port be there yet seem to go no where. Or is it possible that it is terminated undergroud by the pump but never plumbed?
    Just seems strange to go through the troble of putting it there but not hooking it up. I would love to get it working and put my cleaner there instead of at the skimmer.
    Thanks
    Kidney shaped ~ 10000 gallon Ig Plaster pool with pool cage. 120sf Cartridge filter. Pentair WhisperFlo WFDS-26, 230 Volt, 7.8/3.0 Amp, 1-1/2 Horsepower 2 speed pump, Solar panels on the roof. Heliotrope HelioMatic 4000D solar controller.
    Re: Pool plumbing questing
    It is possible that there is a valve that turns that port on and off. The valve might be in a strange place, for example under a cover plate. The valve, if there is one, could be nearly anywhere between the equipment pad and the port.
    Another possibility is that the port was disconnected at some point in the past.
    It is also possible that it is simply clogged.
    Apr 2009
    Sarasota Florida
    143
    So chances are at one time it worked. IF there is a valve then it is buried somewhere as there is only 1 pipe coming out of the ground for suction. Wouldn't there need to be a valve to turn the skimmer off and another to turn the vac on? If so then that means there is 2 valves buried somewhere.
    Apr 2009
    Sarasota Florida
    143
    Well I just don't know. There is no obvious shutoff valve and I really am not in the mood to start digging up my yard looking for one.
    arggh
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Another possibility is that it was added so it could be connected for future use when the pool was built, but was never connected. Cheap to do when you are building, but hard to go back and add it.
    Jun 2008
    Bruce Peninsula - Ontario
    44
    any change it may be pluged? I would try an electric type wire fish and see if it is blocked
    20 X 40, 28000 gal IG cement bottom, steel sides, vinyl liner, Pentair 4X160 pump, sand filter, SWG, Titan heat pump, coluorlogic and fiber optic. concrete-exposed aggregate deck
    1 skimmer, main drain, 4 returns ( 2 in stairs ) JEWEL LIKE WATER thanks to TFP!
    Apr 2009
    Sarasota Florida
    143
    Quote Originally Posted by silcozot
    I may stick a snake in it and see how far it goes. I guess if i hit something it will either be a valve or a cap. If i only make it in a foot then it is probably capped off and was never plumbed.
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    582
    Do you have a main drain? Does the skimmer have two holes in the bottom? It's possible(I think) that they could have plumbed the vacuum port to the second hole in your skimmer. This is a common practice with main drains.
    HTH,
    Adam
    18' x 42" Intex Easyset Pool, with 16' x 52" deep end in the middle. Approx. 5500 Gal.
    Hayward Power-Flo LX 1 HP, 100# Jacuzzi Brand Sand Filter(Piped underground so it looks nice) 8)
    3 - 2' x 20' Solar Pool Heater Panels(roof mounted)
    Goin' on 9 summers...NOBODY thought it would last this long.
    Buried Portable Spa sharing pumps and water with pool (Almost complete project)
    Apr 2009
    Sarasota Florida
    143
    Quote Originally Posted by launboy
    HTH,
    Adam
    Skimmer has 2 holes, one goes to main drain and the other to the pump. Side suctions does not go there from what i can tell. Drained pool by tying the 2 holes in the skimmer together. Once the water got below the side suction i would have been sucking air had it been plumbed to the skimmer.
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    582
    Hmm, well then I guess the only way to figure out where it goes is to snake it, or get a plumber with a camera on a snake to follow it and see what the end looks like.
    Good luck,
    Adam
