Thread: How to Install O-Ring and Header Gasket on Raypak R406a
    Mar 2015
    Buford, Georgia
    16
    Hi,
    This might be a silly question, but I can't get the O-Ring to stay in place while I try to bolt on the header. The O-Ring that came with the part doesn't sit still inside the header and falls loose, but there's no way to get your hand around to set it in place once it's close to being bolted on. The only thing I could think of was some kind of glue to hold it in place, but I'm not sure if that would harm the brand new O-Ring. Any tips?
    Jan 2015
    Maritimes
    56
    Re: How to Install O-Ring and Header Gasket on Raypak R406a
    Some lube should hold it in place
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Just to make sure, use majic lube. Not petroleum based lube.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    Mar 2015
    Buford, Georgia
    16
    Thank you! I didn't know such a thing existed. The header is secure, and no leaks.
