Thread: Ozonator Question
    Ozonator Question
    Hi guys. Would like to revive this thread after so many years.
    I purchased the PZ2-4V last year and just managed to hook it up this week. One thing I'm concern about is the lack of any ozone smell when I have my nose right up against the bottom nozzles. I'm expecting a very strong ozone smell considering its spec'd for commercial use and I know how O3 smells like. The glow is there when it's powered on (via a timer and on 220v).
    The other concern I have is the lack of bubbles appearing when my variable speed pump is set on low speed (less electric bill). The bubbles only starts to appear at speed 3, which defeats the idea of buying a VS pump.
    Help please.
    JoyfulNoise's Avatar
    May 2015
    13,225
    Ozonator Question
    What is the source gas that feeds the ozonator? If it's just ambient air, then the unit is hardly commercial grade. A true commercial grade ozone generator needs to be fed relatively pure O2 gas. Atmospheric gas is 78% N2 and 21% O2 and 1% trace gases. It's very hard to generate substantial amounts of O3 with low O2 partial pressure as other side reaction will happen (NOx formation). As well, any humidity in the feed gas will also reduce O3 production efficiency. True commercial O3 units pair the corona discharge cell with an O2 generator for feed gas.
    Matt
    Apr 2013
    Sacramento, CA
    2,769
    Re: Ozonator Question
    First you need to understand that we generally don't recommend ozonators in residential pools. What that means is there is not a great depth of knowledge here on trouble shooting.
    I suspect your ozonator is working correctly but with lower pump speeds the ozone bubbles dissolve prior to exiting the returns for you to observe. But I don't know.
    Have you gone thru all the troubleshooting in the manual? Look at page 6.
    Can we get a picture of your installation and the entire equipment pad.
