Thread: PH swing in hot tub
    Mar 2015
    Dallas, Texas
    133
    PH swing in hot tub
    Recently switched water in my above ground hot tub 350g. Now I am struggling to keep PH below 8. What gives ? Numbers are the same as before I dumped and I was able to maintain 7.6 with a rise to 7.8ish while in use.
    FC 7
    CC .02
    PH 8
    TA 50
    CH 170
    Build in progress: 31x18 GI (17,336 gallons) / Diamond Brite French Gray finish / Flagstone Coping / 30ft weeping wall with 7 stations plumbed / Salt Finish Deck / Pentair EasyTouch Controls / Pentair IntelliFlo Variable Speed Pump / Pentair D.E. Filter 60sft / Polaris Automatic Pool Sweep w/ Booster Pump.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: PH swing in hot tub
    Did you have borates in the water before? Do you have more aeration now than before?
    Mar 2015
    Dallas, Texas
    133
    No borate I do the bleach method after getting cya to 20 to 30 range.
    Mar 2007
    San Rafael, CA USA
    12,082
    Well I don't know why there's a difference between last time and this time, but I do know that 50 ppm Borates will help buffer the pH so you can get boric acid from DudaDiesel or from The Chemistry Store.
