Results 1 to 12 of 12
Thread: Pump failed prior to closing. Cold green pool
    Nov 2015
    Knoxville TN
    7
    New to site and first post...My ecopump 2 speed went out of service shortly before closing time and I replaced bearings, seal and it still won't run on low speed without tripping thermal switch. (i believe the windings are shot) so I have replaced with 3 speed Speck which is enroute. Its now fairly cool here and my pool is fairly green due to poor maintenance while pump issues dealt with. Also a lot of leaves. I am also awaiting my TFP testing kit to test more accurately but I know my TA is close to 140 driving up pH to the 8 range.. I increased Chlorine to 12 with some 8.25 bleach solution. That seems to be holding above 10 as far as my test strips show. I also added a quart of MA 32.45 to begin working on the TA a bit. I've turned the dolphin loose in there a couple of times just to keep the bottom a little cleaner and I can see the bottom of the shallow end ok, very green and hazy. So, when the pump comes in and I install it, I thought i'd treat the pool as if I'm opening it and clean it up and close it after that. Thoughts and advice much appreciated.
    Thanks!
    24000 gal, Turbocell SWG, 1 1/2 inch pvc, Hayward T60 Sand, Speck m3, Hayward aux pump for cleaner, titanium heat siphon heat pump, Dolphin Premier electric cleaner
    Tons of oak, maple, hickory trees making this pool guy a little loco
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Pump failed prior to closing. Cold green pool
    Hi Smoky
    Welcome to TFP.
    I think you are taking the right approach in cleaning up the pool before you close it.
    Good job on getting that test kit on the way so you can do it properly.
    Divin Dave,
    Aug 2014
    Northern IL
    4,615
    I hope the kit comes soon!! If your weather holds and you can fix things now, Spring should be a breeze!
    Nov 2015
    Knoxville TN
    7
    Thanks for the encouragement. I guess I'm wondering if there are any concerns or modifications I need to consider because the water is so cold as I do this. Glad I found this site; I've learned a lot so far
    Nov 2015
    Knoxville TN
    7
    I guess the thing that has me wondering is the fact that the chorine does not appear to be consumed as expected given the color of the water. But Im not circulating aside from the pool cleaner and brushing. The new pump is coming. Also, I am testing with some aqua test strips while I await the kit. Maybe FC is higher than I thought initially and coming down and the strip only measures to 10 making it look like its not being consumed. I think UPS and the mailman will straighten this out soon.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,318
    circulation is a key part to getting the green out....once you have the new pump in place and running it 24/7 while doing the SLAM it
    should clear up pretty quick to blue.
    Dolphin E10 Cleaning Robot.
    Nov 2015
    Knoxville TN
    7
    Quote Originally Posted by borjis View Post
    Thanks, it comes tomorrow and hopefully our 5 day monsoon will end. It's been raining cats and dogs all week
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,771
    The cya test in your imminent tft kit works better at room temp. Warm your sample up a bit before trying to read it.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,462
    So did it come in? What did you find?
    Kim
    Casey's Avatar
    SW PA
    10,435
    Welcome SMP. I too was wondering how you were fairing with the green pool. Have you started SLAMing yet?
    Aug 2014
    Northern IL
    4,615
    Helloooooo. We are anxious awaiting results!
    Nov 2015
    Knoxville TN
    7
    Sorry. Lost track of this thread. The pool did clean up nicely after I installed the new pump. I believe I had some metals in it as it cleared up but remained a green tint until the chlorine drifted down. I winterized and changed out half the water so maybe the metal problem will be better? Now focused on improperly installed tiles on deck that popped up this spring. I'm busy repairing that and adding expansion joints that should have been there from installation.
