Thread: New Install - Where to run cable?
    Oct 2015
    Tampa, Fl
    29
    I will be installing a new system in the next few weeks and have everything pretty much planned out but not sure how to handle the cable between the cell and the control panel. What is normally done with this? It seems messy to just string it across everything up to the controller. Where it will go is about 3 feet from the wall the controller will be mounted on. Should I wrap this in conduit and bury it to the wall? Curious to see how others handle this.
    Thanks!
    12,000gal in-ground pool/spa 12x26/plaster, 1.5hp Sta-Rite Max-E-Pro pump, Pentair Clear & Clear RP 100 filter
    JoyfulNoise's Avatar
    May 2015
    13,171
    Re: New Install - Where to run cable?
    My cable just runs free from the panel to the cell draped over and around the PVC. We have pack rats and ground squirrels that chew through stuff so you want to keep it off the ground as much as you can if you have wild life. Don't make it too restrictive and tight since you have to be able to remove the cell periodically for cleaning.
    Matt
    Oct 2015
    Tampa, Fl
    29
    Sent from my iPhone using Tapatalk,16k gal SWG pool (All Pentair), QuadDE100 Filter, Taylor K-2006
    Didn't think about having to take it off to clean it, that makes a lot more sense now. My biggest animal problem would be squirrels followed by maybe armadillos or possums. I've never seen them on that side of the house though, they seem to love digging up the grass on the other side of the house.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    I 'S' folded my cable and put a few tie wraps on it, then I tie wrapped that bundle to the side of the pvc pipe. Just snip the tie wraps if you need to take the cell off.
    Nice and tidy.
    Divin Dave,
    Apr 2013
    Sacramento, CA
    2,769
    If you like things neat and tidy you can attach it to the piping with cable ties. But leave some slack.
