Thread: Filter pump wont turn off; filter pump relays keep burning out/breaking
    Nov 2015
    Plano texas
    1
    All,
    I have a Jandy Aqualink RS pool control system. I have replaced the pump filter relay approximately twice now and the same problem keeps arising where the pump wont turn off. I will replace the relay; it works for about a week; then stops shutting off the pump according to the schedule.
    Any ideas? Everything else working fine. Whats causing the relay to burn out too quickly.
    thanks for reading .
    Dec 2014
    Riverside California
    482
    Re: Filter pump wont turn off; filter pump relays keep burning out/breaking
    You have some problem, probably the pump motor that is causing too much current to pass through the contacts in your pump relay and thus causing the relay contacts to weld themselves together and preventing the pump motor from stopping then the relay is de-energized. One thing in the pump motor to cause this problem is if the centrifugal switch in the motor is not switching out the start windings after the motor is up to speed and causing the motor to draw much more current than normal.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,545
    Poolmd1,
    What Gary300 said makes sense, but it would help if you provided a little more info.
    1. Has your system been working fine for some time and just now has this problem?
    2. What recent changes have you made?
    3. What kind of pump are you controlling and at what voltage.
    4. Is anything other than the pump wired to the filter relay.
    5. Is your replacement relay a factory replacement or just a "relay".
    6. What size circuit breaker does the pump power come from?
