Thread: question on adding chemicals during the same treatment and pH down opinion
    Nov 2015
    NSB, FL
    24
    Hi everyone. I've been maintaining my pool myself for a couple of weeks now and things seem to be going well. As new things come up, new questions arise and I would appreciate any advice.
    First, when it comes to pH, I noticed my pH over the last week rose from 7.6 to 8 (we have had quite a bit of rain, perhaps that did it?). I decided to buy pH down instead of liquid MA and will try that. I have read that MA is better but I didn't want the liquid at this point. Maybe later.
    Can I add the pH down and my liquid chlorine during the same treatment time? Or should I wait some period of time between the two?
    Thanks!
    15000 gallon in-ground concrete pool, plaster finish. 1hp Sta-Rite P6RA6E-205L pump, Sta-Rite 2 cartridge filter, Rheem electric heat pump, no spa or water features.
    30,426
    Re: question on adding chemicals during the same treatment and pH down opinion
    Muriatic has virtually no side effects. It is the best.
    That said, what you brought is dry acid and it is fine aside from leaving sulfates in the water.....not enough to worry about long term, I think.
    JoyfulNoise's Avatar
    May 2015
    13,231
    Quote Originally Posted by NSBFAN View Post
    Thanks!
    ALWAYS WAIT.
    Add your pH Down product first (I'd dilute it in 5 gallon bucket of pool water) and then let to the pool circulate for a minimum of 30mins (45-60mins is better). Then add your liquid chlorine and allow it to circulate for 30mins.
    Matt
    Nov 2015
    NSB, FL
    24
    Thank you for the reply about waiting. I will do that in the future. Out of curiosity, what happens if they go in at about the same time? Interact? Lose effectiveness?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Chlorine gas would be generated very quickly. Chlorine gas is very toxic and can quickly overwhelm a person if exposed directly to the gas. Think immediate burning sensation in the eyes, nose, mouth and throat. Excessive coughing... can easily cause you to pass out with possible permanent damage to mucous membranes in the eyes, nose, throat and even the lungs. Fatal in high enough doses.
    Isolated Spa - 345 Gallons
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    You can shorten the wait time if you get in there with the brush after adding the first chemical. A wall whale moves so much water you'll be amazed. A couple strokes each direction should get whatever you've added sent to all corners of the pool in a hurry.
