Thread: Thermal blankets?
    Nov 2015
    Hillsborough
    2
    Thermal blankets?
    I live in NJ, was doing some searches online and just came across a thermal blanket for spas. We have a Sundance Hamilton (2014 model) and it is about a year old. Does anyone use a thermal blanket? Wondering if it's something we should look at as we head into the winter again....Thanks!
    30,421
    Re: Thermal blankets?
    Welcome to the forum.
    I am not a spa guy but I assume your spa is covered already with an insulated cover, correct?
    Mar 2007
    San Rafael, CA USA
    12,082
    If what you are talking about is a thin foam sheet that sits on top of the water, then that's mostly to cut down evaporation to slow down how much water gets absorbed by the hot tub cover, especially when it's water-blocking layer gets broken down. Heat insulation should primarily be from the thick cover over the spa.
    Nov 2015
    Hillsborough
    2
    Thanks. Yes, we do currently have a cover. I was wondering if it would prolong the life of the cover in addition to providing additional insulation. We do have quite a bit of water on the inside of the cover. I'm not sure how long we can expect it to last.
    (BTW, first time posting but I've been lurking and searching these posts for almost a year now as I switched to the dichlor bleach method after screwing up the first fill with really high CYA...Thank you!)
    banditig's Avatar
    Sep 2015
    Ohio
    466
    what type of insulation is it? Fiberglas is basically worthless when wet. Foam should help.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
