Thread: Intellibrites automation for Christmas party?
    Nov 2015
    Lakewood Ranch, FL
    36
    Hi all, first post on this board. I sure wish we knew about this community when our pool was being built!
    Anyways... We're throwing a Christmas party in a few weeks and the wife asked of the pool lights can rotate from green to red. I have the pentair Intellibrites / Automation / Screen logic, etc, but I can't see a way to do this. Only options that are obvious to me are the preset modes (royal, sunset, romance,etc ) and solid colors that are set manually. Any ideas on how this could be done?
    14,900 Gal free-form PebbleTec/Gunnite pool/spa, built July 2015, city water, caged
    Pentair Automation Panel, Intelliflo Pump, Clean&Clear Filter, MasterTemp Gas Heater, Intellibrite 5G Lighting, ScreenLogic2, IC40 SWG
    Paramount Clean O3, In-Floor cleaning system / Solar Heating panels
    TF100 test kit
    Dec 2014
    Riverside California
    482
    Re: Intellibrites automation for Christmas party?
    Welcome to the TFP forum. You will find the answer to almost any question here. I do not think that you are able to deviate from the built in light patterns or fixed color selections of the Intellibrite lights. Also, please visit the pool school portion of this site, and learn why you do not want to use Trichlor tablets in your pool unless you want to face draining your pool each couple of years or so because of high CYA that will eventually make your chlorine ineffective.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    Nov 2015
    Lakewood Ranch, FL
    36
    Quote Originally Posted by gary300 View Post
    Thanks for the tip. Already ordered my TF100 test kit and took my first reading over the weekend. CYA is actually low right now... OK to use up my tablet supply while keeping an eye on it and then make the switch?
    To what, bleach?
    TF100 test kit
