Results 1 to 7 of 7
Thread: Brand new pool owner, white ring around pool edge?
    Nov 2015
    Davis, CA
    5
    Hi! Brand new pool owner here, been a city apartment dweller my whole life. We just closed on the house with pool and I'm trying to crash course myself on how to take care of it. It is a pebbletec IG pool ringed with fake rock. The chlorine is generated by a Chlorine Genie machine. The water looks clear but a bit full of debris since the previous owners moved out. The current water temp is ~45-50oF. As we haven't moved in yet, I haven't been able to do any testing of the water. However, I've noticed a white crusty ring has appeared around the whole pool at the water line since we've been in the negotiation phase of the house purchase. Based on my reading, I'm going to guess this is due to water hardness, which is supposed to be very bad here in Davis, CA. However, I'd love to hear opinions about what the white stuff is from and how to fix it.
    I attached a picture, sorry about the weird orientation. It is correct on my computer, but not when I upload to the forum.
    I'm very excited and nervous about jumping into the deep end of pool ownership! I hope it is very rewarding and thanks in advance. This forum seems like a wealth of knowledge that I plan to tap for a very long time.
    20K gallon IG pebbletec pool
    Chlorine genie SWG
    Pentair control panel
    DE /filter
    30,432
    Re: Brand new pool owner, white ring around pool edge?
    I think you are correct about water hardness. A set of test results will probably confirm that. The only permanent cure is to use softened water as a fill water and slowly the CH will be reduced.
    Meanwhile a dilute (3:1) muriatic acid will probably clean thaty off or minimize it.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,025
    Yup. What duraleigh said.
    Divin Dave,
    Nov 2015
    Davis, CA
    5
    Thank you both! Once I get my measurement of the hardness, where do I look for recommended levels for pebbletec pools? All I see are recommended levels for fiberglass or plaster pools. Thanks!
    Chlorine genie SWG
    DE /filter
    Jul 2015
    Central Valley CA
    1,109
    for chemical levels plaster and Pebbletech / quartz finishes are synonymous.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,025
    ^^^ what he said.
    PebbleTec IS plaster. It just has larger aggregate in it.
    Divin Dave,
    Nov 2015
    Davis, CA
    5
    Great thanks guys! So much to learn.
    Chlorine genie SWG
    DE /filter
