Thread: Rusting Access Panel on Pentair Pool Pump
    Nov 2015
    Lakeland
    1
    My pool was completed 12/24/2015. The transitor access panel is rusting from the screws which, apparently, are not stainless steel or painted. The paint on the panel is beginning to blister from the rust. I tried to replace the panel, but cannot get the screws to move given the significant rust. Any thoughts on what next steps would be to fix this problem? No help from Pentair who says their warranty does not cover rust. No help from the contracor who says the pump is a single unit he installed but the rust is not his problem either.
    13' x 29' Freeform 11,000 gallon Pool. Gunite Construction. Depth 3' - 6.5'. Two Main Drains. Two Return Lines. Pentair CC 150 Cartridge Filter.StarzTruck Automatic Suction Pool Cleaner. 1 hp Pentair SuperFlo Pump. Pentair IntelliChlor Chlorine Generation. LED Lights.Competed 12/24/2015
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Re: Rusting Access Panel on Pentair Pool Pump
    Are the screws burred to the point a screw driver slips? A hammer drill might break them lose. If not you might try a much smaller carbide drill bit to drill through them, then an easy out to unscrew them. Sounds like a pain, especially if you don't have the tools. Or as long panel opens you could sand the rust off and repainted it.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Forgot. You try a little wd40 or other bolt penetrant around screws? Maybe twice a day for 2 days.
