Thread: yellow stains keep coming back
    Apr 2015
    Naples, FL
    6
    Question yellow stains keep coming back
    A couple of months ago I was careless and let the chlorine get to 0. The floor and walls turned yellow. So I brushed the stains off and brought the chlorine back to normal. But the stains keep slowly coming back, though the numbers look good. Is a shock necessary once the stains appear? Is that why it keeps coming back? What ppm will be sufficient? Also, will a shock get rid of the stains that are there now on its own or will I still need to brush it off?
    In-ground 12'x26' oblong, ~8,000 gallons, material is something like a concrete with pebble surface
    Pentair system: 1 HP pump, CC150 cartridge filter, UltraTemp 110 heat pump
    Spa with spillover
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,510
    Re: yellow stains keep coming back
    You need to do a SLAM. It should be a fast one at this time of year with the lower temps. Here is a link. Please note this is a process instead of a one time shock and done. The most important part of the SLAM is the M=maintain. Maintain the FC level at the SLAM level until the SLAM is done.
    Pool School - SLAM - Shock Level And Maintain
    Make sure to keep brushing to get the algae out and into the bleach.
    Let us know how it is going!
    Kim
    Casey's Avatar
    SW PA
    10,444
    I'd suggest not only SLAMing, but understanding why you're slamming the pool and how you got to where you are by reading the ABC's of Pool Water Chemistry which you can find in my signature.
    Piper Mike's Avatar
    Jan 2014
    Bartlesville, OK
    200
    Yes, I'd SLAM too. The ABC's was very helpful for me. I've gone back and read it a few times now.
    Intex ultra frame 26'x52" above ground pool
    Intex ultra 18'x46" above ground pool retired
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,321
    Sounds like you have Mustard Algae.
    The SLAM will take care of it. (did one myself with mustard last june)
    Its a good idea to do the overnight chlorine loss tests a few times/days to be sure
    when you get to that point.
    Don't forget to brush daily...twice if you can.
    Dolphin E10 Cleaning Robot.
    Aug 2014
    Northern IL
    4,615
    How is it going?
