Results 1 to 8 of 8
Thread: Need to confirm WFE-6 compatible 2-speed motor
    Nov 2015
    San Diego, CA
    25
    I am going to purchase a new motor to convert my single speed WFE-6 pump motor. For a sanity check I need to confirm that Pentair motor 071320S will fit on the WFE-6 housing. Could anyone that has done this confirm this is the correct two speed motor that I need. From the description it seems that it will be okay. It's too late to call Pentair tonight. I don't want to purchase it and risk damage.
    Here is a description:
    • Two Speed Motor for 1 1/2 Horsepower WhisperFlo Pumps
    • Two Speed Motor for 2 Horsepower SuperFlo and Pinnacle Pumps.
    • Energy Efficient - Full Rated Motor
    • 3450 RPM High Speed - 1725 RPM Low Speed
    Thank you
    Chris
    Re: Need to confirm WFE-6 compatible 2-speed motor
    That motor will work with your pump. However, I would consider going to a small variable speed pump instead. Even on low, that pump will use over 700 watts. A variable speed can usually be operated at a much lower power. By the time you buy the motor and seal kit, the cost is not that far from a smaller vsp. If the whisperflo is old, it's not unusual to need a new impeller and seal plate. Both of those are expensive.
    It also looks like you might qualify for a $200 rebate for installing a variable speed pump. Check with your power supplier.
    Support the site
    Quote Originally Posted by Chris_N View Post
    Thank you
    Chris
    If you're on a standard Intermatic timer, check out this 2 speed motor that is a direct replacement for that pump- B2983T
    Low speed 1.6amps X 230volts = 368watts
    Nov 2015
    San Diego, CA
    25
    Quote Originally Posted by JamesW View Post
    JamesW - I appreciate the input. I have looked into the VS pumps and YES they are an extremely attractive option. However, I am using a Compool CP3600 controller and my circuit board will not accommodate a VS without the Intellicom. Even with the Intellicom I would not have enough relays to utilize the 4 different settings a VS has to offer. The only combination that makes sense with my CP3600 would be an easy touch upgrade and VS pump. I am trying to utilize the existing controller hence the hesitation. We are also going to go solar electric so we will save there as well.
    You do bring up an important point regarding the motor and seal kit. I will have to weigh the options of buying a new pump versus just the motor and seal kit. If the delta is close enough, I will opt for a new pump and make the old pump a refurb project.
    Thank you.
    Chris
    mas985's Avatar
    Pleasanton, CA
    11,737
    The WFDS-6 uses about 350-400 watts on low speed and that should be about the same for a WFE-6 with a two speed motor on low.
    Mark
    The WFDS-6 lists the operating voltage at 230 and the full load amps at 10.0 high speed and 3.5 low speed. 230 x 3.5 = 805 watts.
    Support the site
    mas985's Avatar
    Pleasanton, CA
    11,737
    Yes, but those are maximum ratings not operating points. A pump motor will usually draw much less than the maximum rating on the label especially on low speed. The numbers I am quoting come from actual measurements.
    Mark
    Quote Originally Posted by mas985 View Post
    OK, thanks.
    Support the site
