Page 1 of 4 1234 LastLast
Results 1 to 20 of 63
Thread: Mottling
    Oct 2015
    Burleson, Texas
    178
    Mottling
    Does this look like normal mottling?
    21,000 gallons, Salt, IG Gunite, Plaster Finish, Free From, Pentair FNS DE cartridge filter, Pentair Intelliflo-VS pump, Intellichlor IC-40, 2 port fountains, bubbler in tanning deck, Dolphin M400, TF-100, K-1766, Speed Stir
    Jaimslaw's Avatar
    Jun 2015
    San Diego, CA
    300
    Re: Mottling
    Age of your finish? Appearing only in step / shallows? Any raised or different texture to it when running hand over areas?
    Pool: 13k gal. in-ground; Stonescape Mini Pebble - Tropics Blue; Connected Spa - dual spill-over; Aqua Rite T-15 SWCG; AquaLogic PS-4 Automation; Sta-Rite DE Filter; Sta-Rite Max-e-Therm 400k BTU pool heater; Intellifo 2-VST Pump; Stenner 45mp2(25psi/10gpd) acid injection; Bulbwizard color LED pool lights; Poolvergnuegen 2 wheel side suction cleaner; FAFCO rooftop solar. TF-100 w/ speed stir.
    Oct 2015
    Burleson, Texas
    178
    Re: Mottling
    Pool has only been filled for 6 days. It also appears on another seat in the deep end. Haven't been in the pool since its new.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,824
    Re: Mottling
    Coloration looks similar to ours. Out mottling is throughout. Some areas are random. Some are in the shape of troweling patterns. All super smooth.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Re: Mottling
    Gray plaster tends to show mottling more than lighter colors. I like it, but it is a personal preference. What does your PB/plasterer say?
    Jaimslaw's Avatar
    Jun 2015
    San Diego, CA
    300
    Re: Mottling
    I'm no expert, but mottling is typically more widespread vs. in small isoltated areas. Not that mottling can't occur in smaller patches...its just that it would be less likely that it would occur in a relatively small proportion of the total surface area.
    Some might weigh in with an opinion that this appears to be more related to poor application/troweling technique on your steps, excess calcium chloride in the mixture, over use of water during finish troweling, or curing issue. But I suspect your PB will attribute this to mottling, which is a standard disclaimer in pool finishing contracts.
    With this appearing on the steps, it would not require much to drain the pool to expose just the steps, so maybe your PB can acid wash the area again to eliminate or dimish those areas. Others here might have a different take.
    Can understand your concern about the look though. Definitely reach out to your PB about these spots.
    Jul 2011
    Arizona & California
    805
    Re: Mottling
    You can see normal mottling (slight shading differences) of dark colored plaster in the areas away from the distinct white discoloration that has occurred.
    The "white areas" are either scaling or bad wet troweling in those particular areas. You should ask the PB to fix it for you. Polishing might remedy the situation.
    Oct 2015
    Burleson, Texas
    178
    Mottling
    I've texted them to the PB. He stated give the plaster 30 days to cure and he would take another look at it. They're already working on the deep end where they put chemicals in before the water was filled and bleached the plaster.
    It looks even worse than that now.
    Jaimslaw's Avatar
    Jun 2015
    San Diego, CA
    300
    Re: Mottling
    I still don't get how or why the PB did a careless dump and run start up, which I have to believe is not a situation remotely experienced by anyone of this forum. I may be wrong but if the plaster color has been bleached out by the PB's inexplicable chemical dumping, it's probably more than what an acid wash will be able to address. Acid baths do darken finished plaster somewhat, which perhaps it the PB's plan, ie, wait for the plaster to cure longer, drain and do an acid bath treatment in that one area. As for any planned attempt to "color" the plaster to make it blend, that is indeed a long shot ... I had that done on an older pool to a small area - worked ok for about 3 years but than the color completely faded/washed out.
    Oct 2015
    Burleson, Texas
    178
    Re: Mottling
    Who would I contact if I feel the plaster was done incorrectly if the PB states it's normal?
    JoyfulNoise's Avatar
    May 2015
    13,262
    Re: Mottling
    Quote Originally Posted by Shock11 View Post
    Did you already make your last payment?
    Matt
    May 2015
    13,262
    Re: Mottling
    onBalance would likely have a better answer for you but there is a "Pool Inspection" form on the National Plasterers Council website HERE. They may or may not be helpful...not sure.
    Matt
    Aug 2014
    Houston tx
    2,525
    Re: Mottling
    If you had a PebbleTec product, you could try contacting them directly.
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Aug 2014
    Northern IL
    4,615
    Re: Mottling
    See posts 9 and 12 (if you haven't already) here: Finally Some Pics
    Oct 2015
    Burleson, Texas
    178
    Re: Mottling
    Sent from my iPhone using Tapatalk,16k gal SWG pool (All Pentair), QuadDE100 Filter, Taylor K-2006
    Haven't made last payment. They are supposed to work on the deep end where they put the chemicals in during fill.
    Aug 2014
    Northern IL
    4,615
    Re: Mottling
    And here: Start Up Tomorrow
    Nov 2011
    Jacksonville, FL
    62
    Re: Mottling
    Although I know this probably absolutely obvious, do not pay until that plaster issue is fixed. It really does not look right.
    34x17, IG gunite pool, Cathedral shape, Hayward Pro-Logic automation, 40,000 gal T-cell 15, Hayward EcoStar VFD, Hayward Star-Clear Plus C1200 Cartridge Filter, Hayward ColorLogic LED lights x 2
    Oct 2015
    Burleson, Texas
    178
    Re: Mottling
    Yea. Hopefully we will hear some good news this week. It seems to get worse every day.
    Oct 2015
    Burleson, Texas
    178
    Re: Mottling
    Update: Builder is claiming the plaster work under warranty. The plaster company is coming Friday to take a look and correct.
  20. Back To Top    #20
    JamieP's Avatar
    May 2011
    Waxahachie, TX (south of Dallas)
    1,135
    Re: Mottling
    That's great news! I'm glad your builder is taking care of it. Keep us posted on what the plaster company says, and how they decide to fix it.
    28,000 gallon freeform, Stonescapes Tropics Blue Minipebble with abalone, 3.5' to 8.5' depth. 2 skimmers, 5 returns, dedicated vacuum port, Dolphin Z5 robot. All Pentair equip: EasyTouch 8, IC60 SWG, VS pump, 520 Cartridge Filter, 3 Intellibrites, 2 Color Cascade Bubblers. TurboTwister Slide and 8' Salt System Jump Board. TF-100. My Jan-Mar 2016 build:
    Waxahachie, TX Owner Build - A race to beat the baby!!
