Thread: New Pool Basic Questions
    Nov 2015
    Mt Vernon Oregon
    23
    I am building an in ground pool in the philippines. Is it safe to assume that the standard piping size for main drains, skimmers, and returns is 1 1/2" ? Would a 1 HP circulation pump be adequate for a 25,000 gal pool ? Also, is there any thing wrong with using the main drain as the fill port ( with proper and according valving ) ?
    30,419
    Re: New Pool Basic Questions
    1.5 inch pvc is fine. The 1 hp pump is fine as well.
    If I understand your question, you would like to fill using the main drain. I see no problem with that but it seems very unnecessary. Why not just fill over the side?
    Jun 2014
    Roseville, CA
    343
    I would advise against using the main drain to fill. It's a generally a bad idea. You may have to use extra plumbing gadgets per building code - anti siphon, etc. Anything hooked to the fresh water supply has to have safeguards to prevent contamination from non potable supplies.
    Just port it into the side with an auto fill device, or use a hose over the side.
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
