Thread: Time for new equipment
    Kahauloa's Avatar
    Nov 2015
    Cameron Park Ca
    1
    my pool is 23 years old and still using the original equipment. 23000 gal 1.5 hp Jacuzzi pump 150 sq ft cartridge filter.
    I would like to replace the filter and the pump. I am thinking a 425 sq ft Hayward cartridge filter pn# c 4030 and a Hayward variable speed pump model # sp 2302 vsp. The pool plumbing is 2 inch pvc. the current clean filter pressure is 16 psi. I put a vacuum gauge on the pump and it read 8. I calculated the TDHP at about 46.
    Any suggestions would be greatly appreciated.
    Thanks
    Paul
    pool built 1993
    23000 gallon in ground
    original equipment Jacuzzi 1 hp pump with Jacuzzi 150 sq ft single cartridge filter
    2 inch plumbing
    Polaris 380 sweep with booster pump
    Apr 2013
    Sacramento, CA
    2,769
    Re: Time for new equipment
    I think there is still a PG&E rebate on vs pumps.
    I'm not a pump expert but that pump seems to work.
    If the price difference isn' much I'd go with the larger Hayward filter. More surface area means lower pressures and longer between cleaning.
    With the vs pump you might want to switch to a Polaris 380 without the booster pump or to save more energy get a robot that you toss in once a week.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Hi Paul,
    welcome to TFP!
    Good choices on the pump and the filter. You'll love them.
    Divin Dave,
    Hayward makes a 700 sq ft cartridge filter if you like overkill.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Yep, 425 is ok but bigger is better. Variable speed pumps a great. Love mine!
