Results 1 to 8 of 8
Thread: Safe Chlorine Level?
    Oct 2015
    San Diego, Ca.
    637
    CYA-60
    ph 7.4
    FC 18ppm (shock target 24ppm)
    Is anything less that the SHOCK target number "safe" level for swimming?
    35,000 Gal. - 40x20x8 - Plaster - SWG Pentair IC 60 - Barracuda G3 Vacuum - Hayward c1750 Cartridge Filter - Blue Torrent VS 1.5hp pump - Pool is 45 years old.
    "I'd build a deck over my pool if I didn't have a SWG"
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,422
    Re: Safe Chlorine Level?
    Phil,
    FC just under the SLAM level is safe to swim.........I would not wear a brand new suit just in case some fading happens.
    Kim
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Yes, it's safe for you. But, as Kim points out it may be harder on your swimsuit - I'll just leave it at that.
    Support the site
    Oct 2015
    San Diego, Ca.
    637
    Quote Originally Posted by tim5055 View Post
    Do people still wear swim suits?
    Aug 2014
    Northern IL
    4,615
    Not here in IL. We wear snow suits now!
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by Philo View Post
    it probably depends on the privacy of your yard and your neighbors
    Support the site
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Quote Originally Posted by MarianParoo View Post
    LOL! Boo for winter!
    Mar 2007
    San Rafael, CA USA
    12,082
    The active chlorine level when the FC is at SLAM level which is about 40% of the CYA level is the same as in a pool with an FC of 0.6 ppm with no CYA so less than found in commercial/public pools. Nevertheless, as my wife can attest to after swimming in an indoor community center pool every winter, her swimsuits would only last for one season (elasticity gets shot) while in our own properly managed pool those swimsuits last for 7 years. It's not that the suits will degrade in a day -- it takes longer than that -- but the effects on swimsuits, skin, and hair are noticeable.
