Results 1 to 7 of 7
Thread: 3/4 Dual Speed Pump vs Intelliflo VS Pump
    Aug 2013
    Marin County
    29
    I have a 14,000 gallon 19x32 Rectangle shape, Depth 3Ft-5Ft. Pool with a Sta-Rite MAX-GLAS II 1.5 HP. I only run it 3.5 hours because my California PG&E hourly price per kWh can range from $0.19 $0.33 depending on my usage which is on a tiered system, meaning that the more electricity I use, I move up to the next tier, therefore pay more per KW. My question is should I pay more for a Pentair VS pump at $900 or get a 3/4 2 speed pump. I want to run my pump 6-7 hours and not and still save $$.
    Sep 2013
    Charleston, SC
    540
    Re: 3/4 Dual Speed Pump vs Intelliflo VS Pump
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
    I would suggest a variable speed pump. Here are some choices that qualify for a $100 rebate (Check with provider for full details)
    Hayward SP2300VSP Max-Flo VS (No clock)
    Hayward SP2302VSP; Max-Flo VS (Has clock)
    Hayward SP2302VSPND Max-Flo VS (Works with Hayward automation)
    Pentair 342001 SuperFlo VS
    Sta-Rite 343001 SuperMax VS
    Zodiac VSFHP165JEP VS
    Variable-Speed Pool Pump and Motors Rebates Database | PG&E
    If you have 230 volt supply, and want a two speed pump, I would suggest the Pentair SuperFlo Product number 340042, Model number = SF-N2-1A. Volts = 230. Amps 6.0/2.3. H.P = 1.0. S.F = 1.25 THP=1.25. 1HP Full-Rated Dual Speed Energy Efficient 230V Pool Pump
    What is your power supply voltage?
    Do you have automation?
    Note: The Pentair 342001 SuperFlo VS is the exact same pump as the Sta-Rite 343001 SuperMax VS except that the SuperFlo is almond colored and the SuperMax is black.
    Support the site
    mas985's Avatar
    Pleasanton, CA
    11,742
    With 6 hours of total run time per day split 5 hours on low(er) speeds and 1 hour on high(er) speeds, here is a comparison of energy use and cost to run:
    MaxFlo XL 1 HP 2 speed: 73 kwh/month
    MaxFlo VS: 38 kwh/month
    The VS uses about half the energy of the two speed but costs $100-$200 more. So at $0.33/kwh, it takes about 12 months before the VS overtakes the 2S in terms of cost savings. So as long as you are going to own the house/pool for more than a year, it probably makes sense to go with a VS. But make sure you install surge protection to protect your investment.
    Mark
    Aug 2013
    Marin County
    29
    I haven't switched out my 1hp Max E Glas 2 pump for a new VS yet, but was ready to get the Pentair Intelliflo 10118, but then I just saw the Pentair 342001 SuperFlo VS Variable Speed Pool Pump which is a few $$ less. I am going to install Pool Solar heating panels, and want to know what pump will be more economical for me. I will also be running a Pentair legend cleaner that is currently running on a Booster pump. The suction Pipe to Pool Pump is 2" and the return line from the Filter to the Pool 1.5".
    My pool: 18x32 White Plaster 13,000 Gal w/ Pentair Intelliflo 2 VST, 3/4hp Pentair Booster Pump for Pentair Legend Pool Cleaner, Sta-Rite 300 Mod Media S7M120 Filter, Heliocol Solar Panels, Pentair Solar Touch Controller, Poolmaster 22260 5-Way Test Kit.
    Sep 2014
    Sunland, CA
    4
    Quote Originally Posted by Extreme21 View Post
    I haven't switched out my 1hp Max E Glas 2 pump for a new VS yet, but was ready to get the Pentair Intelliflo 10118, but then I just saw the Pentair 342001 SuperFlo VS Variable Speed Pool Pump which is a few $$ less. The suction Pipe to Pool Pump is 2" and the return line from the Filter to the Pool 1.5".
    So did you get the 342001 Pentair pump and, if so, how is it working out? I'm about the take the same plunge. I'm just hoping the 342001 at max RPM will give the same output as the old pump (Hayward Super II 1.5HP) when running the jacuzzi. I wish the 342001 had a 2" suction port, but it is a 1.5" so that is about the only negative about this pump that I'm aware of. Thx.
    16x32 kidney shaped in ground pool and jacuzzi, french gray plaster, built with the house in 1987. Hayward Super II pump 1.5HP single speed. Purex 4048 DE filter. Polaris booster pump running Polaris 380 sweep. Pool gets full sun mid morning through late afternoon. Just put on a new solar cover.
    Don't forget to check for utility rebates, can be substantial:
    Pool Utility Rebates | PENTAIR
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
