Results 1 to 10 of 10
Thread: Backside of Waterfall
    Matchless1's Avatar
    Jul 2014
    Baton Rouge, LA
    258
    For those that have a waterfall (or grotto) + slide, I'm curious to know how the back side of that structure was constructed. Obviously, continuing stone (creek rock, moss rock, etc.) would look the best, but I'm also interested in any cost saving options (perhaps stucco?) for this large surface that is rarely seen by anyone.
    Can you please post pics and any info about how yours is constructed and any pros/cons you've learned in hind sight?
    These are a close example of what my waterfall + slide are will look like:
    And these are my rough plans:
    14K gal, Diamond Brite Plaster (Bahama Breeze), Depth: 3.5' - 5.5', Pentair Intellipro XF VS Pumps (2), CCP520 Filter, Intellitouch i9+3S w/ ScreenLogic2, DEL Ozone EC-20 w/ Stenner Pumps for Chlorine & Acid, Flagstone Coping, Moss Rock Waterfall, Dolphin 15.5' Slide, Intellibrite 5G Pool Lights (3), Globrites (2), Kichler Underwater Waterfall Lights (4), Auto Leveler, 4'x8'Techno-Solis Solar Panels (14), Dolphin S300i Cleaner, My Pool Build
    Aug 2014
    Houston tx
    2,525
    Re: Backside of Waterfall
    If you were to put some good sized plants back there then I would think you could go with a finished gunite.
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Matchless1's Avatar
    Jul 2014
    Baton Rouge, LA
    258
    Quote Originally Posted by Marlahoutex View Post
    Not a bad idea Marlahoutex. Unfortunately, I'm short on room back there and would like to maintain every square inch of open space that remains if possible. I was also thinking about doing a stamped and stained concrete sort of like this:
    Aug 2014
    Houston tx
    2,525
    But the plants would also act as a screen from the neighbors and give it a tropical look. If you planted a lot, then you wouldn't even have to mow! What's the dimension from the back of the slide to the fence?
    Marla
    Matchless1's Avatar
    Jul 2014
    Baton Rouge, LA
    258
    I plan to replace our 3' picket fence with a 6' privacy fence. I also plan to plant 3 six-foot (or taller) Sylvester palm trees (shown below). The dimension from the back of the slide to the fence is about 11 feet.
    Aug 2014
    Houston tx
    2,525
    Oh okay, palms will be great! I guess I would ask if you want people to walk behind that area. If you do, then something that would blend in with your decking or just use the same decking would work. Otherwise, I would probably just put low maintenance plants (I like plants in case you couldn't tell! LOL!) and some stepping stones through that area.
    Another thought - If I were a kid, that's the place where I'd hang out so my parents wouldn't be able to see me.
    Marla
    Matchless1's Avatar
    Jul 2014
    Baton Rouge, LA
    258
    No, not really expecting many people back there. Just me and the kids to throw/kick a ball, but not really any guests. Good point about the hide out place. May need to route one of my surveillance cameras back to the corner post when they get older.
    I don't mind planting plants (and the maintenance that comes with them) as long as I (and others) can appreciate them. So planting plants behind that large wall does not really sound like the best use of my pruning time. That's why I'm leaning towards doing the stamped concrete wall right now.
    Jan 2011
    Richmond, Texas
    595
    Mine is all moss rocks but it is not as big. My brother in law had little storage area added under his waterfall/slide. It is big enough to hide floats and chemicals.
    Approx 11K Gal. 10'X30' Semi free-form IG - 6 ' raised spa w/6 jets - 10' circle sun shelf with 1 bubbler - Waterfall - 3 / 1.5 HP pumps - Polaris 280 Cleaner - 3 Pentair Color LED Intellibrite Lights - Pentair 400K Master Temp - 2 Valve Actuators - 5 Fiberstar Mini Laminars - 1 Fiberstars 2004 Illuminator - 2 Skimmers - 6 Returns - Caribbean Blue Pebble Tech - 600+ sq ft kool decK - Auto Fill - 2 Boston Acoustics VOYA RK5 Outdoor Rock Speakers - 2 TIC Corporation TFS5CN 6.5-Inch 150-Watt Terra-Forms Rock Speakers - Apple Airport Express - 1 Awesome View.
    Matchless1's Avatar
    Jul 2014
    Baton Rouge, LA
    258
    Quote Originally Posted by Flippy View Post
    While that does sound tempting to do, especially for short people such as myself (and it has crossed my mind), I'm not sure if the budget would allow it. It also seems like an even more attractive hiding spot for kids, snakes, etc. Do you have any photos of your brother-in-law's?
    Jan 2011
    Richmond, Texas
    595
    Sorry, I do not have any right now. Also his waterfall is not made of natural rocks as it is man made, but looks like real rocks. It is a grotto, slide and waterfall all together.
