Results 1 to 7 of 7
Thread: Crash course needed on cleaning a pool
    No2rdame's Avatar
    Aug 2015
    Jacksonville, FL
    18
    Our pool was finally completed late last week and is filled! Yay! Now, the tough part. The pool company builders came out, did something with the filter over the weekend, and now the pool is ready to be used for the holidays (I know, sounds weird, right?). Here's the dilemma. The other day I noticed that there is a lot of debris in corners of the pool. I didn't look last night at the pool itself but did notice some equipment dropped off on the patio. So, how do I use the hoses/whatever to clean the debris out? The debris has settled to the bottom, so it's not something I can use the net to easily get, although there are a bunch of pvc shavings at the top as well. I've been trying to reach the pool builders, but they are not responding and may be on vacation already.
    The builder says they will show me how the equipment works and what to do, but right now I have a pool and no knowledge of anything and I can't reach anybody. To be fair, with the pool just now being completed and Thanksgiving practically upon us they haven't had a chance to show me anything and it is likely they are just out of town and vacationing like anyone else. However, I need to know at least the minimum so we're not either staring at a pool we can't use or swimming in one with a bunch of sand and dirt at the bottom.
    8500 gallon IG with Krystal Krete Pebble finish, Hayward 2 Speed filter with Star Clear Plus cartridge, Hayward Aquaplus SWG
    Jun 2011
    Long Beach, CA
    2,790
    Re: Crash course needed on cleaning a pool
    What type of vacuum did they give you?
    Did they label any of the valves?
    For now scoop out what you can with the net and if you have main drains brush the debris towards the drains.
    No2rdame's Avatar
    Aug 2015
    Jacksonville, FL
    18
    I couldn't find a manufacturer for the vacuum head, so I don't really know and it's written on my contract but that's at my house. Of course, I didn't look too closely at it since I had a few other things going on when I got home. As far as the valves, nothing is labeled. I have a hose, net, pole, and a couple of other small items but I didn't dig through everything.
    As far as keeping it clean enough just to use, thanks for the suggestion as that will work long enough to use the pool until I can reach the builder. It'll take a little while to scoop up all the pvc shavings on the surface, but that may be the best option for now. I'm also guessing that the best choice to brush the sediment into the filter is to just jump in and brush it in with my hands.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    You should have a brush for the end of the pole that interchanges with the leaf net.
    Like this
    Pool Pals 17 Economy Brush BR1016P | Oreq BR1016P
    Aug 2015
    Orlando
    116
    Normally, the PB will tell you to scrub all surfaces daily for first 30 days, to scrub away any plaster dust. They will probably be scheduling a 'pool school' for you, with complete details how to vac and care for the pool. Shame on them for not giving you the details. Our PB gave us a listing of what to expect when, and pool school was scheduled to arrive day after pool was filled. Thanksgiving surely has thrown a 'turkey' into the works
    Enjoy it will be great soon enough!
    Phil
    ~9600 gal gunite pool, NEW July 2015; Pentair Intelliflo 2 VST pump; Pentair C&C 150 filter; Pentair Intelliclor IC40 swg; solar heat w/ Pentair Solartouch controller, screened. Taylor K 2005 test kit, FAS-DPD separate test, Taylor K1766 salt test
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,575
    Here is a helpful link for you. Just know what the PB says is the last word as HE holds the warranty card!
    Pool School - Start-up New Plaster
    Kim (shhhhh if they did an acid start you can get in your pool now)
    No2rdame's Avatar
    Aug 2015
    Jacksonville, FL
    18
    Thanks everyone. I was able to get in touch with the builder and basically at this point they are monitoring everything daily or every other day. As I was told, just relax and enjoy. We still haven't scheduled any sort of training, but that's because this weekend and next I will be out of town. The builder has been pretty good to work with so far, so I definitely think the timing of the holidays and then vacation that was scheduled almost a year ago has made things a little more difficult than they normally would be. And thank you for explaining why the brushing is a good thing. I was told it's good, but wasn't sure exactly why.
