Results 1 to 7 of 7
Thread: Cover Question
    dsilchenstedt's Avatar
    May 2015
    Rockport tx
    62
    Question Cover Question
    I know they make the inflatable bags to keep a cover off the waters surface but is that necessary? I got an Intex cover and it is resting on the surface. I am going to buy some clamps to help fight the 30+knots we get in our storms down here but do I need to worry about keeping it off the surface?
    Round Frame Pool 15' x 42" (app. 3800 gallons) converted to Krystal Clear 2800 GPH .75 HP (conversion thread Here all the links/info you will need are within), TF100 Test Kit with speed stirrer. My first SLAM
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Cover Question
    It can help in areas where there is significant snowfall to help keep the accumulation of snow from building up on the cover but in your area I'd say they are unnecessary. If anything, having it rest on the surface of the water might keep the winds from affecting it as much.
    Isolated Spa - 345 Gallons
    May 2015
    Rockport tx
    62
    Re: Cover Question
    Quote Originally Posted by JVTrain View Post
    my thoughts as well on helping with the wind. Thank you for the answer, I couldn't really see any point in raising it off the surface other than causing more possibilities of it taking flight. Im going to finish shocking add some algaecide and keep it covered. Maybe add a little chlorine and run the pump every now and again. This has been a fun experience, hoping it all holds up next season.
    dw9000's Avatar
    Aug 2014
    NW Ohio
    184
    Re: Cover Question
    I grew up in the Chicago area (some refer to it as the windy city), I can only say NW Ohio is TEN TIMES WINDIER. Last week this time we had 40mph winds, the week before that 35mph winds. Needless to say I've added numerous more gal jugs of water that I attached with a rope and threw over the side of the coping, onto the tarp (i had to double & triple up the jugs it was so windy). Otherwise it looked sort of like one of those kids air play-pens,, the tarp was up off the water about 20 feet... the Gales of November remembered.
    twas the witch of November come stealin...
    In-ground block / vinyl liner 33' x 22' x 5',, approx 25k gals
    Cartridge Filter
    Floor drains, 2 skimmers, 3 return lines (2" plumbing ultra-flex PVC)
    Feb 2014
    Central Minnesota
    5,080
    Re: Cover Question
    Quote Originally Posted by dw9000 View Post
    40 years ago... Still a remembered tragedy around here as well.
    Larryh86GT's Avatar
    Jan 2015
    Western New York
    93
    Re: Cover Question
    My pool cover held up well in 60 MPH winds last week. Attachment 44036
    Coleman 16' x 48" power steel pool.
    dw9000's Avatar
    Aug 2014
    NW Ohio
    184
    Re: Cover Question
    Yep, I have to say I love the words to that song, twenty-nine men lost everything - 'And all that remains is the faces and the names,
    Of the wives and the sons and the daughters'
    Quote Originally Posted by Larryh86GT View Post
    Looks good, I have the same thing, ropes, jugs, more ropes, more jugs - next year I am getting a loop-loc 'like' cover..
    Cartridge Filter
