Thread: Pool chemicals
    Sep 2015
    Dallas Texas
    53
    Pool chemicals
    Hi
    new pool is under construction and will be done next week. What chemicals beyond stabilizer, chlorine, and muratic acid should I purchase? Also, the pool calculator references "soda ash" for lowering PH; is that the same as baking soda?
    thanks
    Fiberglass pool 5300 gallons (trilogy eclipse)
    inground
    Cartridge filter
    2HP hayward ecostar sp3400vsp
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,197
    Re: Pool chemicals
    I would limit it to those three until your testing reveals the need for something else.
    No, soda ash is different from baking soda and it raises pH rather than lowering it. Check out the ABCs of Pool,Water Chemestry in Pool School.
    Support the site
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,258
    Re: Pool chemicals
    Meaty:
    Welcome to TFP! With many new pools, a PB will supply you with test strips. Here, in the TFP Community, we rely on accurate testing in order to maintain a trouble free pool. If you have not done so, please take a few minutes and read through Pool School, which will provide you a wealth of information. Below is a link to some of the recommended test kits. Once you perform the first set of tests, please post them so we can assist you further. Additionally, there is a link to some of the video's. Thanks!
    https://www.youtube.com/user/TF100TestKit
    Pool School - Test Kits Compared
    Pool School - Getting Started
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
