Results 1 to 18 of 18
Thread: Upgrading gas meter for pool/spa heater?
    Dec 2014
    Cypress, Texas
    200
    Our PB tells us we need to upgrade our gas meter in order to accommodate adding the pool/spa water heater. Have any of you had to do this? If so, what does that entail? Any ideas on cost?
    Mike
    2016 Build: 32x8 Gunite, 6,700 gallon IG pool including 6x8 spa and 6x8 tanning ledge w/ 2 bubblers. 32' raised wall with two sheer descent water features. Travertine Coping w/ split faced Travertine on raised wall face. 2HP VS Jandy pump, 400k heater, Rainbow Chlorinator, 4 Colored LED Lights. 459sqft spray deck plus. IAqualink remote, Polarus 9350 Robot Cleaner.
    Aug 2014
    Northern IL
    4,615
    Re: Upgrading gas meter for pool/spa heater?
    Yup, we did. Our gas company upgraded for free, but that was 10+ years ago. They took care of it within an hour or so.
    Apr 2013
    Sacramento, CA
    2,769
    Who is plumbing the line to the heater? Are you hiring a plumber to do that ? If so the Plumber should call your gas co and make the arrangements. Gas companies like to deal with plumbers regarding gas lines.
    Mar 2015
    atlanta ga
    33
    We did it this month last year (went to a 2# meter) ours was free. We actually moved into a house with a pool and spa but added a bigger heater and didn't have enough flow fr previous line. We have Atlanta gas but most sub out install and we needed new line fr street as well -if ur yard anal like me make sure they shoot line underground or it could be very messy
    30,000 gallon gunite swg, 3HP VSP, Pentair TA-100D, 8' spa w table/water feature, waterfall and PCC 2000 infloor
    SuzfromTexas's Avatar
    Apr 2015
    Houston, Texas
    3,217
    I live in Cypress, too, so I'm assuming you also use CenterPoint. I think ours was upgraded by Centerpoint when they switched us to the remote meter reading system (no more meter readers traipsing through our yard). There was no charge for that.
    Our PB, along with the others we interviewed, all said it was possible we would need to upgrade but to wait and see after the pool was completed. Well, the pool was completed, and nobody ever mentioned it again. Things work fine now, so there must not be a problem.
    The other possibility of when it was upgraded was when CenterPoint rerouted our gas line which was running through the middle of the pool location. I don't think it was done then, because CenterPoint was very precise about every step of that process, and nothing was mentioned about a meter upgrade. But if I'm wrong then, the upgrade was included in the rerouting - about $350.
    I had to contact CenterPoint. They bill you through your gas bill, so they need your account number, etc. The good news is CenterPoint was great to work with unlike moving the cable of the phone/Internet company I use.
    The other good news is I've been pleasantly surprised (so far) at the cost of heating our spa. It may get worse as the water is colder and takes longer to heat. On average, my son uses it about 4-5 evenings a week. He was very worried about the cost of heating it. We've had 3 bills since heating the spa. I told him our gas bills have almost doubled, and he nearly fainted. Then I explained they've gone from about $17 to $30 a month. (our only gas appliance is the water heater). He didn't find my joke very funny.
    Take care,
    Suz.
    Suz~Cypress area~ 2015 pool build. 23K gallons. IG swcg system. 35'x18'; 573sf; 104' perim; depth 4'-7'. Bubblers, sheer descents, 7' spa. Jandy: color LEDs; 2HP 2sp pump; 1HP 2sp pump; spa pump; 580 cartridge; 400K BTU; Dolphin M500; PS8; Inline chlorinator not used; Aqua Pure 1400. Blue Granite Sheen. Travertine deck. Lightstreams Peacock Blue TF-100, K-1766, SpeedStir
    JoyfulNoise's Avatar
    May 2015
    13,193
    With the addition of a 400kBTU/hr heater, most standard residential meters are not large enough. Few household appliances (tank water heaters, forced-air gas heaters, gas stovetops, etc) consume as much gas as a pool heater. As well, most pool heaters have very tight inlet pressure requirements and, if the meter is too small, a sudden drop in gas pressure will cause the heater to shutoff. Natural gas is all about volume and flow as it specifically designed to be a low pressure system for safety purposes. Therefore, you not only need a large gas meter to supply the correct total flow rate for your entire home but also need to ensure that you have a long enough run of feed pipe to have a good size volume of gas to feed the heater with. It is also advisable that your gas line run from the main to the heater either be a single run with no stubs off to other equipment (like a BBQ grille) OR that it be a large enough diameter to accommodate all devices on the line. You don't want to turn on a gas grille or fire pit and suck all the gas away from a heater. The gas line installer (typically the plumbing sub but sometimes a specific gas specialist) should have accounted for all of this.
    Most gas companies don't charge for meter upgrades as they are happy to supply you with more of their product
    Matt
    bdrums's Avatar
    Jul 2015
    The Woodlands, TX
    251
    CenterPoint customer here in The Woodlands. Just upgraded our meter last week. $350 and was paid separate from gas bill.
    Build thread
    IG Gunite w/ spa, PebbleSheen Blue Surf, 18K gallons 500sqft
    Jandy: 60 DE filter, 2.0 VS (main pump), 2.0 Flo Pro (features)
    Paramount PV3 w/ 1.5 Stealth, PDA PS6, JXi 400K NG
    Flagstone coping & wall. Stamped Concrete from BrickForm. TF-100 w/Speed Stir.
    May 2015
    Fullerton, CA
    635
    Mine has to be replaced also. Not sure if there is a cost? It is what it is.
    33x19, 3'4"-5'6", 7ft spa, baja reef, 14'x9', 18" deep, 10,668 Gal. Quartzite coping, Stonescape Tropics Blue mini-pebble, abalone & glass beads. Jandy Equip.(JXi heater, 2.7HPVS pump, PLC1400 SWG, CV580 filter, Aqualink, LEDs)
    TF-100, Doheny Discovery robot.
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    My brother in law is a plumber. I just checked with him about mine. He told me not to stress over it because if we need one, the gas company will replace it at no charge to us. Whew!
    Denise-TFP Guide
    IG 13.6x30 gunite, Radiant Fusion Topaz, 3.6/5.6/4, 14100 gal, 2 skimmer, 4 Hayward LED lights (pool & spa), Hayward Echostar VSP, 2 future fire bowls, raised beam wall w/ scuppers,7x7 raised spa, DE Progrid70, SWG Hayward Goldline, OmniLogic, Hayward 400K BTU heater, stamped colored deck, Dolphin Discovery robotic cleaner, TF100 test kit, Newbie in Bixby Oklahoma
    May 2015
    13,193
    Just remember that in a lot of areas, YOU, the homeowner, are required to call the gas company for final hook up. PBs and plumbers are not allowed to touch the gas company's equipment. Check local codes and with the gas company as well because they may require a copy of the signed and approved permit showing that the gas line passed pressure testing before they will hook up anything to their service meter.
    Matt
    Dec 2014
    Cypress, Texas
    200
    Thanks Everybody! Like the other Houston area Forum Members, we do have CenterPoint Energy for gas (is there any other options for gas?).
    I guess I will call them to set up the upgraded meter once we get final HOA approval.
    Aug 2014
    Houston tx
    2,524
    Quote Originally Posted by Mamiamjo View Post
    Beans?
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    May 2015
    13,193
    Quote Originally Posted by Marlahoutex View Post
    Beans?
    I read this and couldn't help but think about Blazin' Saddles
    Matt
    Dec 2014
    Cypress, Texas
    200
    Just an update. Center point told us it would be $350. to upgrade the meter they also said they couldn't do it until the pool was filled with water.
    Aug 2014
    Northern IL
    4,615
    Crazy that.
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Problem with mine is I'm responsible for the line from the meter. 275 feet worth.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    Yep, that's the way Centerpoint operates. I live in Katy.
    You won't be running your heater during pool startup window anyway (at least a month), so the timing won't be a problem. My pool was complete in November 2014. Once I started filling, I called the gas company. Before they would set up the meter upgrade appointment, they had to have $350 up-front payment. Less than a week later, a guy showed up in a pickup truck with every gas meter imaginable. He looked at the appliances in my house and asked me if I was ever planning on upgrading (e.g. tankless water heater). Since the price was the same to me (and I had already paid it!), I ended up with a 2Million BTU/hr meter. This thing is huge!
    There are a couple of reasons why they make you upgrade the meter. First, your existing meter may not have enough capacity to run your various household appliances/furnaces and heat your pool. Second, pool heaters take a lot of gas. For long runs (and yours is definitely long!), they do a partial step-down in pressure so you can run a 1" line to your pool heater and still have sufficient volume of fuel to run the heater. You'll then have a 2nd regulator at the heater to step-down to normal gas pressure. You'll also have a 2nd regulator at your meter to step-down your house gas pressure to normal levels.
    I would assume that the extra gas they sell should more-than-compensate them for the new meter, but they charge you any way!
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    Mar 2015
    Sugar Land , TX
    424
    I had to upgrade via Center Point also , $350. I had to run outdoor fireplace, grill, 2 fire bowls on pool, pool heater, and the house appliances. Well worth it. The spa heats quick and the fire bowls put out consistent flames. Never have had a pressure issue with multiple appliances running.
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
