Results 1 to 8 of 8
Thread: Newbie
    arata's Avatar
    Nov 2015
    Homosassa florida
    2
    Newbie
    Hi
    We are from the upper gulf coast area of Florida and have enclosed our pool so that we can enjoy it all year long. This year we had rain and humidity for three months nearly everyday! and never could enjoy he pool area or did our cats. So we built a large sun room all around it and converted our pool to salt. We are having a climate controlled AC with humidifier installed soon to control the humidity and hopefully the dangerous chemical smell of Chlorimine. However, this morning we opened our home to a toxic smelling sun room after the pool ran during the night!
    Now we are looking into getting completely fresh water pool treated by an ionizer to eliminate the chemical cholorimine smells and don't want to be fooled anymore like we were when we installed a salt treatment system and thought that would lower the chlorine to where we would be safe with an indoor pool.
    Can anyone help us please?
    Kind regards
    Felice
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,009
    Re: Newbie
    Hi Felice,
    welcome to TFP.
    If the pool is sanitized and chlorinated properly and the water is clean, there should be no toxic chloramine smell, regardless of the sources of chlorine. Chloramines and the odor that goes with it, is a result of chlorine being oxidized while killing off "stuff" growing in the water.
    May I ask how you are testing the water and what the water parameters are? Or is someone else testing it? In reviewing the water parameters, we might be able to better advise of what the problem might be.
    The best recommendation as well that I or anyone could give you right now, is to aquire a reliable test kit, such as the TF-100 or the Taylor K2006C. Then test your water yourself and post the results here. The test strips and pool store testing are notoriously poor methods of determining what the pool needs, and we promote self testing here with a good test kit.
    Divin Dave,
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,585
    Re: Newbie
    HI! I LOVE your area of Florida! We have visited quite often!
    For right now you need to open all of the windows and doors to the outside to air the pool room out.
    With your pool being inside some of the levels and ways of dealing with it will be different BUT the basics are the same!
    You NEED a good test kit! Here is the link to the test kits we use and love!
    Pool School - Test Kits Compared
    You can look in my siggy below to see where to buy them.
    Saying that...........we need your pool info. in your siggy. Here is how to do it:
    -Go to settings
    -look on left hand side for edit signuture
    -add this info.
    Signature
    Please put the following information in your signature.
    The size of your pool in gallons
    If your pool is an AG (above ground) or IG (in ground)
    If it's IG, tell us if it's vinyl, plaster/pebble, or fiberglass
    The type of filter you have (sand, DE, cartridge) and, if you know, the brand and model of the filter.
    If you know, please tell us the brand and model of the pump, and mention if is it a two speed or variable speed pump.
    Date of pool build/install, particularly important if less then a year old.
    What kind/model of water test kit you are using
    Other significant accessories or options, such as a spa , SWG, or cleaner
    Please mention if you fill the pool from a well or are currently on water restrictions
    A picture of your pool and set up would be wonderful as well.
    If you do an reading on here you will see we do not use the ionizer. We use chlorine.
    Lets get you a good test kit THEN we will get into what you need to do with your pool.
    Kim (cats?? what kind??)
    Jul 2015
    Clearwater, FL
    83
    Re: Newbie
    I'm a bit south of you in Clearwater. We did get quite a lot of rain this summer. I had to dump water several times and then rebalance chemicals, particularly CYA (stabilizer) and calcium hardness. It took some time to get everything back into balance. I am a newbie at pool ownership; we bought the house with a suffering pool at the end of February, and at the end of April we filled it after having it resurfaced and all the equipment replaced. We had a salt water chlorine generator installed, and we almost never have a chlorine odor. The strongest smell of chlorine is about the same as the bed sheets might have after using a little bleach when you wash them.
    The advice I've gotten here has been fantastic. If you follow the TFPC method, you will have a sparkling pool with little effort. Pay attention to the advice you get here. If your pool has issues, it might take some time and effort to clear them up, but the members of this forum will walk you through the task.
    16K gallon IG exposed aggregate pool with Aquarite SWG T15 cell, Hayward C1750 filter, EcoStar SP3400VSP pump, H400FD pool/spa heater, Polaris PB4-60 booster pump, 280 pressure cleaner, Hayward Super II spa pump and Air Supply Silencer spa blower
    arata's Avatar
    Nov 2015
    Homosassa florida
    2
    Re: Newbie
    Thank you all for your advise. We have an indoor pool now and we do get a chlorine smell even with the salt system. Yours is outside where you won't smell it. When I keep the windows open we can't smell it either. However,....
    We took a sample of our water today to the pool supply company and found it was high in chlorine. We are going to run the system at a lower number with the windows open and later when the chlorine levels are low where they should be in a salt system then we can see if this will still make the air smell bad when we close the windows.
    I did add the pool info in my sig after I did my post, but I don't see it now. Here it is again.
    10000 gal granite in ground pool. Salt water system.
    Kind regards
    Felice
    PS, I thought I would be an email when someone replied to me but I didn't. Sorry I was late replying to all of you.
    Enclosed 10,000 gallons in ground granite pool with a saltwater system. Enclosed with a glass windows and skylights.
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Re: Newbie
    You really need your own test kit. Pool companies are notoriously wrong most of the time. Even if your pool is indoors you should have minimum odor.
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    Aug 2014
    Northern IL
    4,615
    Re: Newbie
    We would all agree that we can fix your current situation with minimal expense, the largest being a testkit which will be under a hundred bucks. What would the ionizer cost you in comparison?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: Newbie
    What is your CYA level? Having CYA at 30-50 should help.
