Thread: What is a plaster pool?
    Oct 2015
    Melbourne , Australia
    47
    Hi I have a question to clarify what you define as a plaster inground pool. Just checking the translation between USA and Australia.
    I have a concrete inground pool that is fully tiled with glass tiles. Is this a plaster pool?
    I ask as I would like to determine what my TA and CH should be.
    Thanks
    55k Lt IG Concrete Fully Tiled,1-HP Waterco multispeed pump, Waterco s602 Eco glass filter, Chemigem D10 controller with auto pH feeder and SWG Sterisel (SaltigemSG30) self cleaning, Maytronic Dolphin SupremeM4, Solar Heating.
    Jan 2012
    'burbs of Augusta, Georgia
    7,350
    Re: What is a plaster pool?
    Well I would still call that a "plaster" or "cement" pool (unlike a fiberglass or vinyl pool) because you have to take into consideration when maintaining your water to balance the chemistry levels so that they don't degrade or damage the cement, tile and grout. For example the calcium in the water is important so as to not leech out the calcium from the pool into the water although calcium is not important to vinyl pools and is debated about with fiberglass pools.
    Oct 2015
    47
    Thanks Yippeeskippy for the clarification
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Just to expand on YippeeSkippy's explanation, a vinyl pool is any pool with a vinyl liner whether in or above ground, regardless of how the shell is constructed. A fiberglass pool is usually a one piece pool shell constructed entirely of fiberglass, but can also be a wood or concrete pool lined with fiberglass. Plaster pools have plaster, pebble, or tile finishes and have particular calcium level requirements to maintain the pool.
    Love TFP? Become a
    TFP Supporter!
    mas985's Avatar
    Pleasanton, CA
    11,737
    I would only classify a plaster pool as one which has a plaster product (i.e. calcite) over gunite or concrete. A pool that is concrete with ONLY tiles applied to it, I would call a tile pool.
    Mark
    philboyj's Avatar
    Jul 2015
    Houston TX
    326
    Tile pools are so unusual in the USA - primarily because of the cost. So most forums do not have that classification. My guess will be to follow the requirements of the gunite / concrete pools since tiles use cement grout.
    Dippa, please post a pic of your tile pool...thanks in advance.
    Geometric pool with all Pentair equipment. Raised spa - 18" with Artic Lagoon 1" glass tiles. 3HP VS Pump, 2 skimmers, 6 returns, IC40 Salt system, Easy Touch 8 with LED color light in pool and spa. 1200 sqft of Marble White Pavers decking in Versailles pattern. Tiling and coping almost completed, Indigo Blue Prism Matrix plaster. Pool Build Thread: Houston (Katy) Pool Build - Started April 2016
