Choices for AG pool automatic vacs?
May 25, 2007
766
My dad has a 24' round AG pool. He's considering an automatic vac, but has no idea where to start.
What are the choices of styles and the pros and cons of each for AG pools? He only has the 1 hp pump with one skimmer and one return.
Suction side cleaners work pretty darn well for round pools, especially if they are not dished out or have a deep side. When you get different shaped or longer or have high coves, dished out sides, etc they will miss things because they just look for the path of least resistance and ALWAYS travel there so you have to persuade them to get odd spots. Most of them (mine included) have settings so the random patterns they take can be changed (larger circles, more sides, more side to side) I like mine ok except for whats mentioned above with odd spots and I would like something that doesn't require hoses as they sometimes get a bit tangled or twisted so you have to move it occassionaly.
Mine is a Lil Shark, the Tiger Shark is the bigger model. Aqua Bugs and Diver Daves are basically the same thing as the Lil Shark with the different top on it and they have wheels. Any of them work decently. Sometimes wheels can wear out, some have flappers that can wear - the more moving parts, the more that can go wrong on the suction sides but they are pretty basic. A leaf canister inline will also reduce the times you need to stop and clean out the skimmer. Some will not pick up larger debris, some will. Mine does and I also have the leaf canister.
Thanks a bunch :)
Your info lead me to some places to research and I believe I now understand the differences between the automatic cleaner types. I've also recommended the 'lil shark to my Dad, found it for $125 new :)
Of course this may have also cost me money, as I've been researching suction cleaners my IG pool, which leads me to my next thread... :)
This is year 6 with my Lil Shark and not a single repair issue yet. Too bad I get lazier each year, if the Lil Shark would just go out there, put itself in the pool, deal with hoses, etc., it would be much nicer. Lol
Good luck!
