Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: 24 Hour Test Results
    Oct 2015
    Burleson, Texas
    178
    The pool has been up and running for exactly 24 hours. The builder put in some tabs, acid, and some sort of shock. There is no salt in the pool yet. Here's what I just tested:
    FC: 9
    CL: >5
    PH: >8.2
    CH: 375
    TA: 140
    CYA: 35
    CC: .5
    Advice please...
    21,000 gallons, Salt, IG Gunite, Plaster Finish, Free From, Pentair FNS DE cartridge filter, Pentair Intelliflo-VS pump, Intellichlor IC-40, 2 port fountains, bubbler in tanning deck, Dolphin M400, TF-100, K-1766, Speed Stir
    Jul 2014
    Hope Mills, NC
    567
    Re: 24 Hour Test Results
    What are you testing with?
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    Oct 2015
    Burleson, Texas
    178
    TF-100
    Aug 2014
    Northern IL
    4,615
    I would get that pH down as soon as you can. Since your kit only tests to 8.2, pH could be higher. If you have time, do it in two doses.
    30,414
    +1 on get your pH down.......and keep it down....around 7.5.
    No more tabs. You can make a final adjustment to CYA later.
    read "The ABC's of Pool Water Chemistry" up in Pool School. That'll help you understand why you are doing these adjustments.
    Oct 2015
    Burleson, Texas
    178
    The builder will be coming back today or tomorrow and stated he would be adding some acid. I'm waiting until they are completely through as not to void any warranties.
    Oct 2015
    Burleson, Texas
    178
    PB stated not to worry about the chemicals until after they come and do pool school which will be sometime after Thanksgiving. Should I just let it ride or should I get some acid in the pool and start lowering the PH and TA? He also turns on the bubbler every time he stops by but I thought that would raise the PH so I turn it off....
    30,414
    Get your pH under control, despite what your builder says. Don't worry about TA. Harsh comment follows......You have a good test kit so use it and understand what the results mean......I don't think your builder does.
    Did you read "The ABC's of Pool Water Chemistry" up in Pool School? It will tell you that high pH is not a good thing.....ever.
    Oct 2015
    Burleson, Texas
    178
    I have read everything and that is what is bothering me. I don't want to do anything to void any warranties since they are still working with a spot on my plaster. I'll head out in a few and get some MA and get it in the pool this afternoon.
    Jul 2015
    Central Valley CA
    1,107
    I would lower the PH, I assume they won't be back till Monday and you don't have to admit you added anything. Also and make sure you don't have any return eyeballs pointing across any benches or shelves or you run the risk of V shaped plaster marks (ask me how I know ) If you do have a return above a shelf point it slightly up it may lower TA a bit but that will be minor compared to marking the plaster.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Oct 2015
    Katy/Texas
    411
    I wouldn't tell the PB that your adding chemicals and keep a log of the test results.
    In ground, 14,000 gallon, white plaster, unheated, stone waterfall, DE Filter, Rainbow 320 Cl, Polaris 3900, FloVis flow meter, F100 test kit, Circupool RJ30+ SWG, Circupool VJ1/Speck Badu EcoM3V variable speed pump.
    Oct 2015
    Burleson, Texas
    178
    Quote Originally Posted by atttech-2 View Post
    I did notice that the returns are pointed up towards the water and I could stand to lower the TA. Last test was 140.
    Quote Originally Posted by WASP View Post
    I don't plan on telling them and I'm using the Jesse's Graphical Testing Log from the site to keep track of tests. It says I only need to add 3 cups of MA to bring the PH down but I will need to add and re measure because it was above 8.2.
    Aug 2014
    Northern IL
    4,615
    What is your pH now?
    Oct 2015
    Burleson, Texas
    178
    I'm going to remeasure in the morning and ad MA. I got home too late this evening.
    Aug 2014
    Northern IL
    4,615
    Aw, get out there... Hahaha. Did you add any MA yet?
    Oct 2015
    Burleson, Texas
    178
    Not yet. I wanted to measure again. The PB was here yesterday working on a plaster issue and I'm not sure if he came by today and added anything.
    Aug 2014
    Northern IL
    4,615
    Well, let us know your results as soon as you test. Many people with new plaster have sneaked in MA while the PB was away.... You like your PB, I get that as I like mine, but they don't often understand the foundations of proper pool chemistry. Chemistry is different than construction. Keep us in the loop!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    It is important to keep your PH at 7.8 or lower, especially in the first 30 days.
    Pool School - Start-up New Plaster
    more here
    Why new plaster that is curing raises pH?
    pH rise in new plaster?
    Oct 2015
    Burleson, Texas
    178
    Glad I measured before adding MA. Current readings:
    FC: 5
    CC: .5
    CL: 3
    PH: 7.2
    TA: 60
    CH: 350
    CYA: Didn't test due to overcast weather.
  20. Back To Top    #20
    Jul 2015
    Central Valley CA
    1,107
    Looks good, I would check it again about the same time tomorrow don't be surprised if goes up to 7.4. You might make it to next week without having to add any MA but my guess is by Saturday afternoon it will be nearing 7.8 My pool is 3 weeks old 13K gallons PH raises .1 to .2 per day FC loss has been less than .5 per day, I have been adding 10oz of 31% a day to keep it near 7.4. All that being said since it looks as if they have it dialed in if you want to let the PB handle it till they officially hand it over I think you will be fine, even if you go out of range a bit I doubt it would be long enough to cause any problems.
