Thread: soda blasting
    Dec 2013
    San Antonio, TX
    38
    soda blasting
    Has anyone ever used this process to get rid of the white ring or calcium build on your pool tile? If so what the outcome, good or bad? Would you recommend doing it? Any side effects? Does it mess with the water balance? What process did you follow when doing it? Thank you in advance for your input.
    San Antonio TX 14K Gal in ground free form jandy vs pump with DE filter polaris cleaning system with auto feed chlorinater, JandyJXi400N natural gas heater
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: soda blasting
    This guy did it. He used blasting beads instead of baking soda though.
    Blasting limescale off my pool walls - DONE REPORT POSTED
    Divin Dave,
    Dec 2013
    San Antonio, TX
    38
    Re: soda blasting
    Anyone else have any input?
