Thread: Hot tub heats up but not to set temperature on controller?
    Nov 2015
    Martell/Nebraska
    1
    I have a 2004 sundance optima hot tub that I had problems with last winter. I had to replace the heater and manifold I also replaced the hi limit sensor and flow switch. Now the tub heats up but not to control panel setting? What do I need to do to trouble shoot this problem?
    Jeff J
    Sep 2013
    Charleston, SC
    538
    Re: Hot tub heats up but not to set temperature on controller?
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
    Nov 2015
    VT
    85
    How far off is it?
    Hot Springs Sovereign (1999?)
