Thread: How late can you wait to winterize?
    Jul 2014
    Manalapan, New Jersey
    98
    We are buying a home, central new Jersey, and they have a good sized gunite chlorine pool. It is now Nov 21, temperatures at night dip down into the 30s, and they have not winterized and closed their pool yet. They said "soon." Should I be concerned? There has not been any significant freezing but how late is too late? Does it have to be consistently below freezing to have issues? Thanks
    23k gal in-ground gunite w/ spa/blower, Sheer descent, Jandy AquaPure SWCG, Pentair 2HP Pump x2, Raypak P-R406A-EN-C 399k BTU gas heater, Polaris 380/Polaris PB4-60 Pump, DE filter w/ separation tank
    JoyfulNoise's Avatar
    May 2015
    13,254
    Re: How late can you wait to winterize?
    The biggest concern is not the pool (huge volume of water = long time to freeze) but the equipment like the pumps, skimmers and filters. If the pool pump has freeze protection (automatically turns on when the temp goes below 34F), then that can protect it for a good long while. I would have expected a Jersey pool to be closed by now simply because closing a pool is a labor-intensive and wet process. I would not be happy going out in 40F daytime temps trying to mess with pumps, hoses, air blowers, cold water, etc...You need to be worried once the weather starts forecasting extended freezing temperatures (night and day temps below freezing). When do you close on this deal? Perhaps you can make it a condition of closing that the pool be professionally closed on a specific date and offer to pay half the cost.
    Matt
