Results 1 to 11 of 11
Thread: Start Up Tomorrow
    Oct 2015
    Burleson, Texas
    178
    Start Up Tomorrow
    Well the pool will be filled tomorrow and the PB will be back for startup. He's already put something in the bottom of the pool while its filling and dropped off the rest of the chemicals. Not happy about the tabs though. Can't wait to get rid of those.
    21,000 gallons, Salt, IG Gunite, Plaster Finish, Free From, Pentair FNS DE cartridge filter, Pentair Intelliflo-VS pump, Intellichlor IC-40, 2 port fountains, bubbler in tanning deck, Dolphin M400, TF-100, K-1766, Speed Stir
    Aug 2014
    Northern IL
    4,615
    Re: Start Up Tomorrow
    Congrats!!!!! What is that cloud? If that's some kind of chemical, get out your brush right away.
    Oct 2015
    Burleson, Texas
    178
    Quote Originally Posted by MarianParoo View Post
    I asked him if that was ok and he said yes. If they mess up the plaster it's in them to redo it. They've built many polls in my neighborhood and my neighbor sod they did the same thing and it turned out ok.
    Aug 2014
    Northern IL
    4,615
    I would still brush it up to circulate it. It's never good to leave any chemical sitting on a surface.
    Oct 2015
    Burleson, Texas
    178
    I went ahead and brushed in the water to mix it up but didn't touch the plaster.
    Oct 2015
    Burleson, Texas
    178
    Start Up Tomorrow
    I went and brushed again to mix it up more and it looks like the chemicals took away the grey color. I'll be sending the pics to the PB in the morning. Guess they'll have to replaster that area.
    Aug 2014
    Northern IL
    4,615
    Glad you got it up then. Good for you. How deep is the water now?
    btw, Is that the shadow of a palm tree?
    Oct 2015
    Burleson, Texas
    178
    I'm about a foot or so under the tile now. That's actually a shadow from the water hose and bottle taped to it. No landscaping until spring except for the sprinkler and new sod.
    Oct 2015
    Burleson, Texas
    178
    All the chemicals have been put in by the PB and the pump turned on. My instructions were to brush at least twice a day. He filled up the tube holding the chlorine tabs. When should I start worrying about measuring PH and such? Salt won't be going in for 30 days.
    Aug 2014
    Northern IL
    4,615
    Response posted here: Finally Some Pics
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Quote Originally Posted by Shock11 View Post
    That 8 lb pail of Trichlor pucks will only add 30 CYA to your 18000 gallon pool. That's just fine. Your builder didn't leave you some 30 lb drum. Trichlor is also acidic and should help with the pH rise from the curing plaster. Don't be anti-puck! We're not opposed to using any chemical, as long as it doesn't add anything you don't want or need.
