Results 1 to 12 of 12
Thread: cleaning cartridge filter
    Mar 2015
    South Texas
    411
    My basic question is why do you think I'm having to clean my cartridge filter so frequently? When clean the pressure is at about 10 psi. It seems to rise to 20 within a week or two. Granted, I could probably go longer before cleaning it but I notice a SIGNIFICANT restriction in flow at 20 psi, so I clean it then and it really is fairly dirty. Lots of stuff comes out.
    I wonder if I am just really too attentive to it but for maximum skimming I prefer maximum flow. I've read people going an entire year without cleaning. I just don't think I could do that!
    15,000 gallon free form Viking fiberglass pool. Hayward Star-Clear Plus C12002 cartridge filter. Hayward Swim Pure Plus T-15 SWG. Testing with TF-100 Kit. 2 speed 1.5HP Supreme pump. Dolphin Nautilus robotic cleaner
    JoyfulNoise's Avatar
    May 2015
    13,201
    Re: cleaning cartridge filter
    Perhaps your filter is undersized to your pool volume. Bigger is always better with cartridge filters.
    Do you use skimmer socks to capture the big stuff? What kind of debris are you finding when you clean?
    Matt
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Sent from my iPhone using Tapatalk,16k gal SWG pool (All Pentair), QuadDE100 Filter, Taylor K-2006
    This and
    Isolated Spa - 345 Gallons
    Oct 2015
    San Diego, Ca.
    641
    I'm not sure if this would help but I have a Hayward leaf canister in the vacuum hose for the creepy crawly thing. I use an old sock tucked in the strainer basket with the edges rolled over the top of the basket. When I clean out the canister basket once every 2 weeks there is a lot of fine dirt trapped in the sock. I put a fresh sock in and am glad all that dirt (mud) didn't get to the filter cartridge. When I get a dozen dirty socks, I just put them in the washing machine and re-use them.
    35,000 Gal. - 40x20x8 - Plaster - SWG Pentair IC 60 - Barracuda G3 Vacuum - Hayward c1750 Cartridge Filter - Blue Torrent VS 1.5hp pump - Pool is 45 years old.
    "I'd build a deck over my pool if I didn't have a SWG"
    Mar 2015
    South Texas
    411
    That's a great idea about the sock in the skimmer. To answer your questions, I usually clean some bugs and a few leaves out of the skimmer basket but the filter seems to be mostly sand/fine dirt.
    Do you use these?
    Amazon.com : Pool Filter Savers - Skimmer Socks (5-Pack) : Swimming Pool Cartridge Filters : Patio, Lawn Garden
    And my numbers are as follows:
    FC 7
    CYA 50
    PH 7.8
    CC 0
    robdac's Avatar
    Jun 2014
    Weston, FL
    232
    If the pressure is going from 10 to 20 then the filter definitely needs to be cleaned. Where is the dirt coming from? Is it blowing into the pool from an open field or something. I clean my filter about once a month and the pressure only rises by 2 psi (from 10 to 12) in that time. I have a 150 sq/ft cartridge filter. You're getting the dirt from somewhere around the pool and it needs to be cleaned that often because of the pressure rise.
    11K gal IG screened-in plaster pool w/ spa
    pentair 150 cartridge filter, Pentair Intelliflow VS pump,
    Aquarite AQR15 SWG, AquaCal Heatwave Heat Pump, TF-100 test kit
    Mar 2015
    South Texas
    411
    Quote Originally Posted by robdac View Post
    That makes sense. We don't have concrete yet and there is a ton of sand/dirt around the pool. Maybe after we get concrete it won't get so dirty. My filter is the Hayward C12002 (120 sq. ft)
    Oct 2015
    San Diego, Ca.
    641
    "Do you use these"?
    I used to but they seem to rip easily. I just went to the dollar store and got 10 pair of men's dress socks. They have lasted 7 years so far. I also double them up in the basket.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    yeah,
    the fact that you dont have any concrete yet is a big contributor. Even after you get it, you'll find you still have to clean your filter fairly regularly though. A 120 sq ft filter isnt going to provide you a long time between cleanings.
    Quote Originally Posted by nlindelldc View Post
    Divin Dave,
    Jun 2013
    South Florida
    118
    I clean my cartridge filter every 1-2 weeks. It is probably under sized, plus my pool is open air with lots of sand around the area. Oh and the 75 lb. black lab tearing through the yard and jumping in the pool on a daily basis doesn't help either. I just rinse it out with a high pressure hose nozzle. Part of my weekend routine...
    10,000 gallon in ground diamond brite, Circupool si30+, Hayward C900 cartridge, 1.5hp Flotec single speed pump
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,817
    Cartridge filter sales in the US just went down after you posted that!
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Most of the time algae is the cause of rapidly clogging filters. Nothing clogs up a pool filter faster than dead algae.
    You can raise your FC up to 10ish and Pool School - Perform the Overnight FC Loss Test (OCLT) to see if there is an issue.
