Thread: Starite Heater Cycles on and off
    Nov 2015
    Orlando FL
    1
    When I turn on the starite spa heater the temp shows 77 degrees. Outside air temp is 79.
    I turn on the heater and have it set to heat to 104. The heater fires up normally, and runs 2-3 minutes then shows 180 temp followed by r8, and the heater shuts down, and service heater lite comes on. Then within a second it starts back up again and repeats this cycle. Any suggestion on which part is causing the issue?
    Nov 2015
    San Diego
    171
    Re: Starite Heater Cycles on and off
    I'd start with the thermal regulator. We had a similar issue with ours. Apparently it's a common failure on these heaters. About $50. Good luck.
    30K, in ground, raised bond beam, w/attached spillover spa, chlorine, Pebble-Tec, Pentair FNSPlus 60 DE filter, 2 Jandy waterfalls, Intelliflo VS 3hp (filter), Whisperflo 2hp (spa jets), Whisperflo .5hp (water features), Sta-Rite 400K heater, a bunch of Jandy valves, a couple of automatic valve switches, 3 SAm lights, CompPool 3600 controller, Waterway Chlorinator (not used), Pool Vergnuegen, Pentair in-ground check valves ...
