Thread: TFP vs. TFTestKits Levels
    May 2012
    Flower Mound, TX
    130
    Not much of a difference. But, why is the recommended levels a little different from each other. Example for Plaster with Bleach.
    TFP (TFP website)
    PH 7.5-7.8
    CH 250-350
    TA 70-90+
    CYA 30-50
    TFTestKits (card w/TF100 kit)
    PH 7.2-7.8
    CH 250-400
    TA 60-90
    CYA 40-50
    Just asking
    14,000 gallon IG DiamondBrite pool with 2 ea. waterfalls and slide, Hayward Tristar 2.0 HP 2-speed pump, Hayward 3/4 HP waterfeature booster pump, Hayward 48sf DE filter, Hayward PS4 wireless controller, 1 skimmer and 4 returns, Polaris 280 pressure cleaner w/booster pump, 7 x 7 spa w/6 jets, TF-100 Test Kit w/speed stir
    JoyfulNoise's Avatar
    May 2015
    13,244
    Re: TFP vs. TFTestKits Levels
    The Recommended Levels on TFP website were recently adjusted and changed. Not sure how often the TFTestKits card gets updated. Follow the website guidelines.
    Matt
    30,431
    I think those variances demonstrate two things.
    1 We need to keep the two values the same and we are slack in not updating the TFTestkits site.
    2. These numbers get tweaked often...perhaps unnecessarily at times. The good thing to remember is both sets are well within what we think are safe ranges so you won't go wrong but we'll work on getting them to align.
    May 2012
    Flower Mound, TX
    130
    Thank you for the feed back. Ok, then. I will use the Recommended Level Chart on TFP.
    THANKS
