Thread: Trichlor pucks or bleach in winter months
    Mar 2015
    Las Vegas NV
    460
    My pool is remaining "open", I've removed my SWG for the winter and I'm trying to decide whether or not to use bleach to maintain my FC (btw, do I need to maintain it at the same level as during the summer?) or use Trichlor pucks. My only concern with the pucks is raising my CYA so high that when I "open" the pool I've got to drain water to reduce the level.
    Any tips here?
    SUMMER 2015 BUILD IG gunite 38 x 31, 28,000 gal, 110' perimeter, Intelliflo VS, Whisperflow 3hp, Intellibrite LED x2, Clean & Clear 520, Screen Logic, Intelichlor 40, Quartzscape Blue, K-2006C, Speedstir, Aquanaut 400 (4 wheel The Pool Cleaner)
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Trichlor pucks or bleach in winter months
    I would use bleach. Using trichlor will elevate your CYA level, then you'll need to drain in the spring to lower it back down. Bleach is not as convenient but will prevent problems. If you have a cover of any kind, you can eliminate some sun exposure to reduce chlorine degradation so that you can likely go longer between testing/dosing.
    You should maintain the minimum FC at least for a manually chlorinated pool at your current CYA. So likely 5-6 ppm FC if your CYA is 60-80. Below 60 degrees you shouldn't be losing much FC per day, even better if you can cover.
    Isolated Spa - 345 Gallons
    Mar 2015
    South Texas
    411
    I would agree with JV. This is my first "winter" with my pool and I have been amazed at how little chlorine it uses due to the lower temps. I have found that I am manually dosing a half gallon of bleach two times per week. Not bad at all and super easy!
    15,000 gallon free form Viking fiberglass pool. Hayward Star-Clear Plus C12002 cartridge filter. Hayward Swim Pure Plus T-15 SWG. Testing with TF-100 Kit. 2 speed 1.5HP Supreme pump. Dolphin Nautilus robotic cleaner
    JoyfulNoise's Avatar
    May 2015
    13,204
    Question - why did you remove the SWG? Do you get hard freezes?
    I leave my SWG attached and just run my pumps in the afternoon so that the pool water is warmer and I'm more likely not to get hit by the cold water cut-off on the IC40. I'm only running at 3 hr/day and 20% output on the cell and my FC is still too high (9.2ppm last time I checked).
    Matt
    Aug 2013
    Oklahoma City, OK
    139
    Quote Originally Posted by QingGuy View Post
    Any tips here?
    Why remove the SWG at all living in vegas? I don't really understand the purpose of that.
    20000 Gallon, Sand Filter, IG Plaster, Hayward Aqua Rite 40k SWG, TF-100 Test Kit, Taylor SpeedStir
    30,420
    Any tips here?
    Everything begins with test results. We at least need to know your current CYA level.
