Thread: Anode added to pool system to help avoid corrision of heater
    Our pool man added an anode (i think it is called that - see pic) to our pool system to protect the heater from corrision. We run the pool year-round but we do have freezing weather. Someone mentioned to me that we should cover the anode in the winter to keep it from cracking and causing a water leak. Does that make sense and if so what should I use to cover it?
    Thanks!
    East TN
    13,000 gal San Juan Fiberglass Pool;SWG; GoldLine Pro Logic Controls
    Hayward Sand Filter; Hayward Max-Flo XL Pump;Polaris 380; Hayward ColorLogic LED
    Raypak Gas Heater
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Anode added to pool system to help avoid corrision of heater
    Proper water chemistry should prevent corrosion of the heater. Galvanic anodes are by design, supposed to corrode. That anode to me just looks like another point of failure for the plumbing or the beginnings of a moonshine still.
    Isolated Spa - 345 Gallons
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    As Joel points out, anodes are seldom necessary, but as folks from my youth used to say, it can't hurt......
    From the photo I can't see that it will be any more prone to freeze/cracking than any of the other plastic parts thT are exposed to the weather.
    Support the site
    Mar 2007
    San Rafael, CA USA
    12,082
    Is the anode the wire coil and is it just sitting on top of the pump strainer or is it going through the top of the strainer so that some metal is exposed to pool water? Anodes are most effective if they are buried in moist soil. If they are just loose in the air, they won't work as well. They still work a little in that they can still corrode in air, but moist soil is better since you want a higher corrosion potential for the anode so that it imparts a higher negative charge on the bonding wire to which it's attached.
