Thread: Brushing- skimmer off or makes no difference
    Mar 2009
    Charlotte, NC
    539
    My one jandy valve splits the skimmer & drain line, so I assume if one is Off then the other has more power/suction? If yes, when we brush we are after the debris getting to the filter- is this better acheived by the drain? So turning the skimmer off while brushing ( and maybe 5-10 min afterwards) is a bit better or makes no difference? I think of the skimmer as as surface region cleaner.
    Thanks
    19,800 gallons (closed/winter 18,654 gal); plaster; 18x34 Ft kidney bean shape, Depth 3Ft-5Ft. Built 1992
    Pentair Whisper Flow Pump 1HP. Winter safety cover w anchors.
    Sand filter, Pentair Sand Dollar Top Mount Model SD80; Effective Filtration Area 3.5SF
    - FlowRate 75GPM, 8Hr 36,000, 10Hr 45,000, 12Hr 54,000; Pressure Weight 50PSI
    BBB (Hayward Chlorinator when leave town). Polaris 360 cleaner.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Brushing- skimmer off or makes no difference
    You are right on all counts, I'm not sure if one setting is better than the other? I think the point of brushing is to keep the "icky stuff" suspended and not sitting on the floor, thereby making it easier for the filter to get it out of the water. I usually have mine on 50/50.
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    If your pump will stay primed on main drain only then brushing toward the main drain with the skimmer closed is ideal. Just be sure to turn your skimmer back one when you're done
    11,969
    We'll occasionally turn the bottom drain on full, and the kids and I will make a 'whirlpool', while I brush towards the center....sucks everything down and I rarely have to vacume. Then I switch back to 50/50. Works great, but we look a little silly. Kids love it though
    Mar 2008
    Wake Forest, NC
    128
    That they do. I remember as a kid doing that all the time and it was so much fun. We however did not have a drain. Dad just put the vac head down in the middle and it all just disapeared. The most fun was reversing direction when done and trying to go against the current.
    Quote Originally Posted by frustratedpoolmom
    IG Vinyl liner, 21,500G sport bottom, TR-60 sand filter, 3/4 HP Whisper Flow, BBB with 12.5% Liquid Chlorine
