Results 1 to 10 of 10
Thread: Slip-style Return fitting: Need to re-attach
    Nov 2015
    Moraga, CA
    3
    Hello all:
    This week I found one of my return nozzles on the floor of the pool. Turns out it is a slip-style fitting (no threading on fitting or return pipe).
    After reading several related posts, it seems that these slip-style fittings are supposed to be knocked into the return pipe, and are meant to hold fast without glue or adhesive.
    I placed the nozzle back into the return and gently hammered it in place. (Place a 2x4 over the fitting so that the hammer did not damage the fitting.)
    That held in place for several hours under pressure from my , but then loosened and dislodged again. I definitely took it easy re-inserting the fitting so as to be on the safe side and not damage the plumbing.
    My next step is to really whack that fitting back into the return pipe, but I am hesitant to move forward before getting more advice.
    Anyone encounter this scenario before? What is standard practice to get these slip-style fittings in place?
    This is a superb form that has steered me right on several issues in the past. Any commentary much appreciated.
    BayAreaPool
    In ground, gunnite
    20' x 40'
    35,000 gallon
    30,426
    Re: Slip-style Return fitting: Need to re-attach
    Welcome to the forum.
    Most all of those fittings are threaded. Do you know who makes that slip-style? That seems really problematic.
    Pvc glue is always an option (poor one, IMO). Perhaps others have some insight into that fitting and can offer better advice.
    Jun 2015
    Wildomar, California
    423
    Try to rough it up with sandpaper or score it with a knife
    Jul 2015
    Central Valley CA
    1,109
    Idea 1 try pushing it in one more time perhaps a bit more forcefully. If the fitting tapers even a little perhaps you can get a wrap or two of Teflon tape around the pipe before you put the fitting on. If that works it will bunch up and bind hopefully holding the fitting, if it does not work it will not cause any damage.
    2 put a small pin drop of PVC glue inside the fitting and let it dry to create a bump that will bind the fitting against the pipe.
    If option 2 does not work you might be able to take it a step farther and create a slot/flat spot length wise on the pipe with a knife or a file ending in a 90 degree turn at the end. You line up the bump on the fitting with the slot push it on and twist at the end to hold it in place.
    I would avoid glue and if you ultimately do have to use it I would only put a spot large enough to hold it but may still be possible to remove it if need be.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Sep 2015
    Austin, TX
    59
    If it's not too much of a problem, could you upload a picture of that nozzle?
    -Matt
    20k Gunite/Fiberglass
    Hayward SP2302VSP
    Pentair LA-MS05 BoostRite
    Pentair Quad D.E. 100 sq ft
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    My slip fittings were a loose fit to the wall pipe. I built up their diameter by laying on one or more coats of PVC cement (solvent weld type). I let them dry overnight so there was no chance they would "glue" themselves into the wall pipe. Next day I installed them and they were a nice fit. Haven't seen any returns on my pool floor even though my Kreepy Krauly tries real hard to dislodge them.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Sep 2014
    Bakersfield, CA
    155
    I had the same problem. You need to look for "self aligning" fittings. These fittings have a bulge in the straight section and require more force to hammer them into your return piping.
    This image will show you what I mean by a "bulge" Buy Infusion Pool Products Inlet Fitting, Venturi, Self-Aligning Slip, White # VRFSASWH Fast Shipping !
    Cheers, Peter
    20,000 gal, 52'x17' kidney shaped IG, Pebble Tec, IntelliPro P6E6VS4H-209L pump. Intellichlor IC40 SWG.
    300 sf Sta-Rite System 3 cartridge filter. Poolvergnuegen 4-wheel suction pool cleaner. TF-100 test kit.
    Nov 2015
    Moraga, CA
    3
    Thanks all for the suggestions. I will try these options and post a result. Will also post image of the nozzle for reference.
    Great responses in a short period of time. Thanks so much.
    In ground, gunnite
    20' x 40'
    35,000 gallon
    Nov 2015
    Moraga, CA
    3
    Following up to close this thread. I reviewed all the great suggestions, and started with the simplest first. Fortunately, that did the trick. Applied a small drop of PVC cement to the fitting, let it dry overnight and that added enough width to the fitting that I got a good fit after lightly hammering the fitting back in. Used a section of 2x4 to prevent damage from the hammer head to the fitting. Tapped it back in under about 12 inches of water but that was fairly easy and probably helped ensure that I didn't whack it in too forcefully. It's been in place over a week, and no issue. Thanks again to the group. Pool was trouble free for a few days until I started to see a drop in pressure on my filter. But that's for my next post. I ain't supposed to be easy.
    In ground, gunnite
    20' x 40'
    35,000 gallon
    philc's Avatar
    Jul 2015
    Grand Island Nebraska
    190
    Thanks for the update!
    Intex 22' X 52" Ultra Frame AGP ( 12K gallons) , Intex 633T 2500 GPH (41 GPM) running Doughboy Silica II sand filter (16"dia. 1.4 ' S.A.) ( And doing it quite well, I might add!) Hayward through the wall skimmer, TF100 with Speed Stir. Hard plumbed, Intex fountain ...........
