Results 1 to 8 of 8
Thread: Help with labeling valves
    Nov 2015
    Bradenton, FL
    5
    Can someone help me in labeling my valves and drains from this pic?
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Re: Help with labeling valves
    Need more information you have 4 pipes to filter. Looks like heat pump. How many skimmers? Spa? Returns, ect
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    Nov 2015
    Bradenton, FL
    5
    Quote Originally Posted by banditig View Post
    1 skimmer, two deep end returns, two returns in the spa. Heat pump. Spa with spillover into the pool.
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,255
    Anything coming into the pump is the "suction side", which includes your skimmers and Main Drain. The piping coming out of the filter is the "return side, which includes your return jets and the spa jets. I would recommend to have someone with you as you test each valve. It appears you have 4 shut off valves from the "suction side" and you only mention of 1 skimmer. I believe you have others? Is it possible to take a few more pictures from all angles, which include the sides, etc. Maybe a picture of the pool as well. Thanks and Welcome to TFP!
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Quote Originally Posted by GeorgeInFlorida View Post
    Just to make sure everyone is speaking the same "language", the returns are the jets close to the surface of the water that return water to the pool and the drains are typically the large grates at the bottom of the pool that pipe water back to the pumping system.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Catanzaro's Avatar
    Jul 2014
    2,255
    It does becoming confusing sometimes because of how AC Units are labeled. Supply is the air coming into a home, while returns is what is being sucked out of the home to the unit (kind of reverse).
    I guess using "return eyeball jets" may be more appropriate. Both the MD and the skimmers pipe water back to the pumping system (pump) at the equipment pad.
    banditig's Avatar
    Sep 2015
    Ohio
    466
    I've seen so many different configurations with pools nothing is standard. People have water features, spas, even swim jets, there is only trial with help if you don't have the builders schematic
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    I can't help with your pipes, but I want to pass on something I found useful-
    My pipes were all labeled with the source of the water and an arrow direction showing which way the water is traveling. I took a photo on my phone of the entire set up. Over time as weather decayed labels or lightened the sharpie "permanent" marker, I've had to refer to this pic stored "in the cloud" to relabel things.
    Just a suggestion
