Thread: I'd like to understand my pool plumbing
    Nov 2015
    Santa rosa ca
    15
    I have a pool with an attached spa. In the spa I have 2 supply lines on the wall that are adjustable. There are also 2 returns on the bottom. The weird pipe is a 2" that comes out of the wall. When we sit in the tub it really does nothing but you can feel cold water inside of it. Is this a balance type of pipe between the pool and the spa? Where do you think it goes from there? Is it just a part of the supply lines to the main pool?
    Thanks.
    JoyfulNoise's Avatar
    May 2015
    13,199
    Re: I'd like to understand my pool plumbing
    A picture says a thousand words....
    Matt
