Results 1 to 15 of 15
Thread: Pentair ScreenLogic2 Interface Wireless
    Feb 2015
    Cypress, TX
    35
    Does anyone have any experience with this equipment? I installed one this past spring when switching to the EasyTouch 8 automation system. It has worked flawlessly until this past weekend. I can't connect via apps on the iPad or iPhone, nor the desktop program. The system still works fine, running the last current set-up I had programmed, I just can't control remotely anymore. I get an ERROR message saying "address invalid".
    JoyfulNoise's Avatar
    May 2015
    13,227
    Re: Pentair ScreenLogic2 Interface Wireless
    I assume you checked your router to see if it is still listed in the device records? Is this WiFi or hard-wired connection to your network?
    Matt
    Feb 2015
    Cypress, TX
    35
    It's WiFi and the Network Protocol Adapter is plugged in via LAN connection to the wireless router
    May 2015
    13,227
    Dumb follow-on question (makes me sound like Microsoft tech support) - you rebooted everything again I presume?
    Matt
    Feb 2015
    Cypress, TX
    35
    Yes I rebooted the router, and the wireless adapter/protocol adapter. The only thing I have done is disconnect the wireless antenna wire on the terminal at the EasyTouch. Not sure this would do anything as I did throw the breaker on the EasyTouch. Just strange as it worked fine Saturday night. I operated the hot tub and lights via iPhone. Then Sunday morning it won't connect.
    May 2015
    13,227
    Even dumberer question - Did you contact Pentair Tech support (1-800-831-7133)?
    I know sometimes people write-off tech support as "oh, they'll never answer the phone" or "I'll be on the line for hours" but I have actually heard good things about Pentair's phone support. I called them once about something relatively minor with my SWG and they were totally happy to help me. It sounds like you're having a communications issue between the NPA and the EasyTouch panel. A quick glance of Pentair's chat support line and it looks like there's the potential for it to be either a bad antenna or a bad NPA. So Pentair will probably be able to diagnose it the quickest.
    Matt
    Feb 2015
    Cypress, TX
    35
    I put in a request on-line yesterday and got an automated assigned to email but haven't called yet. I plan on calling today after work. Thank you!
    May 2015
    13,227
    OK.
    Yeah, I'm kind of a phone call guy when it comes to stuff like that. Unless they have a direct chat feature, I never trust the automated e-mail requests.
    Good luck! Keep us all posted on what you find out.
    Matt
    Matt
    Feb 2015
    Cypress, TX
    35
    Will do for sure!
    Mar 2013
    Gilbert, AZ
    12
    Pentair has an update for the system, have you downloaded it yet? Mine stopped when I updated my Mac. Downloaded new updates and it's working again.
    34x18' 18,000 gal in ground pebble, Pentair 3H VS pump, Pentair FNS Plus 60 DE filter, IC40 SWG, Easytouch 8 w/ screenlogic 2.
    Jul 2011
    Broken Arrow, OK (Tulsa)
    294
    I'd echo Airboy's reply....
    It's entirely possible you need to update your Screenlogic software and firmware. I noticed the same issues you saw, where the system was operating fine manually, but I couldn't control it remotely. Updating took care of things.
    16 x 31, Approx. 12,000 Gal Freeform IG pool; Flagstone coping; Quartzscapes Super Blue plaster finish; Tanning ledge w/2 bubblers; 1 HP Pentair Whisperflo pump, Pentair sand filter; (2) Pentair Intellibrite LEDs w/controller; Easytouch8 w/IC-40 SWG; Salt finish concrete decking.
    Feb 2015
    Cypress, TX
    35
    Well from what Pentair Tech Support says (and you were right JoyfulNoise, they are very helpful) it's the protocol adapter itself. I did have all the latest updates on the firmware and software installed. I'm sending him just the adapter and he's sending me another.
    Dec 2014
    Riverside California
    482
    Good to hear that you are getting a good response from Pentair, I have a Screenlogic myself which still works great but nice to know they will stand behind it.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    Dec 2014
    482
    Well, my protocol adapter went out today, wont connect with my router. It is 8 months old, installed by me. Pentair is sending out a new one today, and I do not have to return the old one. I call that customer service. Kudos for them.
    May 2015
    13,227
    I have to this for my 8-button EasyTouch RF remote - it has never gone out on me, not one single time in all the years I've had it. I know everyone loves the ScreenLogic interface and all, but the NPAs seem to me to be a real weak-link in the chain. Glad to hear Pentair is stepping up though, kuddos to them.
    Matt
