Thread: TX Pool Build: Skimmer Lid Coated in Spray Deck Material?
    Oct 2015
    Houston/Texas
    2
    Hello! I need some quick advice!
    My pool builder installed concrete/deck expansion joints, skimmer lids, and umbrella anchors in the wrong color. To remedy this, they intend to use the spray deck material to cover everything, including the skimmer and anchor lids.
    I am concerned because I have never seen this done on any pool. Also, it seems that this material is a sealer for concrete, not plastic. How well will the sealer adhere to the plastic long term? Will it scratch easily? Will the lids function properly? Will it be hard to seat the lids?
    I hate the color of the joints, lids, and anchors, but I would REALLY hate scratched, damaged areas of the deck over the long haul.
    Can anyone shed some thoughts and/or experience with this?
    Thank you!!!!!!
    I have a salt water pool if that matters.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,672
    Re: TX Pool Build: Skimmer Lid Coated in Spray Deck Material?
    Hummmmmmmmmmm call the maker of the spray deck and see what they have to say..........You can also ask him if he has done this any where else and to give you the phone number so you can call them and ask how it is holding up.
    I am with you that I do not think it will hold up on the sleeves or lids. He might need to redo it all!
    Kim
    Oct 2015
    Burleson, Texas
    178
    All of our neighbors including ours has been sprayed also. Haven't heard of any problems.
    21,000 gallons, Salt, IG Gunite, Plaster Finish, Free From, Pentair FNS DE cartridge filter, Pentair Intelliflo-VS pump, Intellichlor IC-40, 2 port fountains, bubbler in tanning deck, Dolphin M400, TF-100, K-1766, Speed Stir
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,945
    If spray deck is just another name for textured acrylic deck coating, it is a two step process. The texture is applied first, followed by the color top coat. The top coat is very durable and it could even be applied by itself without texture. If it peels or scratches, it's simple to recoat.
    chiefwej
    Oct 2015
    Houston/Texas
    2
    Thank you for the responses! I wish they hadn't made the wrong color choice to begin with.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,945
    Skimmer lids are easily replaced and readily available in a number of different colors. The PB should be able to change those at least.
    When I recoated my deck with color top coat I removed the skimmer lids, but still painted over the little rim around the lid. None of them have chipped scratched or peeled.
    chiefwej
