Page 1 of 8 1234 ... LastLast
Results 1 to 20 of 147
Thread: New Austin, TX Owner Build
    Sep 2015
    Austin, TX
    144
    Just submitted the permit for my owner build, pretty basic pool in Austin, TX, and anxiously anticipating this journey!
    Building a play pool for my children as they are little fish, and it's so warm in Austin. Ages: 9, 6, 5, 3
    Simple 16k gallon, SWG, 33x19, 490 sq ft freeform pool with 18" raised wall (with sheer) and sun deck (with bubbler).
    Designs attached.
    Setup:
    PebbleSheen
    Oklahoma or Quartzite coping
    400 sq ft patio with koolcote
    Equipment:
    Pentair Intelliflo VS 3 HP pump
    Hayward 27" sand filter
    Aquarite 40k SWG (AQR15)
    1 Pentair Intellibright 5G Color LED pool light
    Polaris 360
    Debating about:
    -Filter choice (thinking sand because I'm lazy)
    -Whether to pay $3k for a heat pump to extend swim season
    -Automation (really only desire here is for color led light to turn on cool colors every night between certain hours - thinking about having electrician hook it up to a standard outlet where I can attach a simple holiday timer)
    -Oklahoma vs Quartzite coping (will come down to cost difference)
    Thanks for all of the advice and knowledge that you've contributed to this forum as it's helped me a lot so far.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    Re: New Austin, TX Owner Build
    If you are going to have a salt pool in a climate like Austin TX, limit the amount of stone you use. At the very least select the hardest and least porous types, and seal it regularly. There is a reason you can't find many pool builders in Austin that will build a salt pool.
    chiefwej
    Sep 2015
    Austin, TX
    144
    Thanks for the tip.
    I actually raised this question in another thread: SWG Coping Ideas
    It seems that Oklahoma stone sealed with Dry Treat might hold up (?) and quartzite is super hard but expensive.
    Sep 2015
    Austin, TX
    144
    I geeked out a bit tonight and drew up my own set of pool plans and design using Pool Studio demo.
    360 video: untitled_004.avi - Google Drive
    Swimming video: untitled_008.avi - Google Drive
    Dimensions: pool2.pdf - Google Drive
    Depth: depth1.png - Google Drive
    Pic: untitled_014.jpg - Google Drive
    Construction underway.
    33x23 freeform 16k gallon IG pool, pebblesheen, SWG in Austin, TX
    Pentair 3HP VS pump, Hayward 30" sand filter
    Build thread: New Austin, TX Owner Build
    Jan 2015
    Austin, TX
    1,095
    Welcome to TFP! Is that mount Bonnell?. Just kidding. Great job drawing up the pool! We have three kids 12, 6, and 4.
    I went with a very oversized cartridge filter so I wouldn't need to clean much too. My father in law loves sand filters. He thinks I will switch to one because I will hate the cartridge filter. My neighbour has a DE filter and loves it so who knows.
    Do you already have a lot of deck? You'll find 400 isn't much. I ended up picking a builder who had 900 in the plan and I am glad I did. 900 even seems small to me now. The other bids I got were around 450 and I probably would have been disappointed. Your pool seems about the same size as mine and I think it is a decent size.
    I will be interested to follow your build. I haven't seen an owner build in Austin.
    Pool is done! Only took 17 months! - Natural shape in-ground pool: 37x23, 505sq ft, 96ft perimeter, 7ft deep end, 18,950 gallons, tanning ledge, blue surf pebble sheen/luminous blue blend, Belgard coping, 910 sqft paver deck/walkways, retaining walls out the yinyang. Jandy SWG, 2 LED Color lights, VS 2HP Pump, 460sqft cartridge filter, PDA RS P8 controller. My build
    Jun 2014
    15,040
    I suspect that besides the basic filter capacity parameters, it will boil-down to personal preference. Just in case, here's our comparison page if you haven't seen it already: Pool School - Pool Filter Comparison. As for the LED lights, I'm sure your builder can wire your lights on their own circuit to something simple like and Intermatic 104 timer or something. Or at least so that you have the option to install one later if you're not sure how you want to do it right now. As for a heater ... again... personal preference I suppose. I personally like a short break from the constant pool maintenance since we typically have a long season anyways. Just going out there in Nov - Mar to sit and relax by the pool is nice enough for me. Supposed to get chilly tomorrow. Bundle-up, and welcome to TFP!
    Sep 2015
    Austin, TX
    144
    Quote Originally Posted by ummgood View Post
    Thanks for the advice. I upped it a little bit to 532 sq ft. Here's the pic with furniture. Unfortunately, I can't put patio on the right side of the pool due to septic field setback requirements. I have a huge yard (.6 acres), but the septic field limits what we can do.
    Pic: deck.jpg - Google Drive
    Layout: moreDeck.pdf - Google Drive
    On the filter, it seems like there's no clear winner as they all get the job done. I think all things being close, I'd want the option with the least maintenance. I'm not sure whether that's sand filter or a large cartridge.
    Quote Originally Posted by Texas Splash View Post
    Thanks for the advice. The intermatic timer looks like would do the trick. (Clarification: I think I need to ask my electrician to hook that up for me - I'm doing the GC).
    Jan 2015
    Austin, TX
    1,095
    That deck looks good and like you will have space for chairs and a table. I see rocks there in that photo. I am anti rock with little kids. I know my son would be throwing them into the pool.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,439
    I am in to watch this one!
    I have to say I agree with ummmmmm about the rocks. They WILL get into the pool. Much better to had a hard surface there.
    For me the sand filter is the easy one. I had a cartridge filter and find the sand one much easier. The filter does all of the work for you. All you have to do is turn the handle!
    Kim
    Sep 2015
    Austin, TX
    144
    I didn't even think about that. The intent with the rock was to sort of transition from the natural landscaping and stacked stone wall to the pool. I think we could train my kids not to do that, but little stinkers that come over would totally do that.
    I tried a design with patio there instead. It's only 2-3 feet width, but it might work. Let me know what you think compared with the rock (or if you have any other ideas what to do in the small space between the wall and the pool):
    With rocks: untitled_031.jpg - Google Drive
    With patio: untitled_027.jpg - Google Drive
    Concrete side
    Thanks for helping me think of things I hadn't.
    Aug 2014
    Houston tx
    2,524
    You could put a little green there by planting some liriope or some other grass type plants.
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Jul 2012
    Tallahassee, FL
    30,439
    What is the purpose and size of the wall?
    I like the patio look better AND add in Marla's idea and will work.
    Kim
    Sep 2015
    Austin, TX
    144
    Quote Originally Posted by kimkats View Post
    Kim
    Thanks for the advice, Kim and Marla.
    As to the purpose of the wall, it's an existing retention wall. There's a big sloping hill there (6 feet tall). You can see it in my original post on this thread (the last pic). The wall is about 3-4 feet tall (gets shorter as it goes out).
    Jan 2015
    Austin, TX
    1,095
    You could cement in river rock with some planters every few feet.
    Jul 2012
    Tallahassee, FL
    30,439
    Okay so it is not the huge flat wall as pictured in the sketch. That is much better!
    So go with a combo of idea. Ummm's idea of putting the river rock in cement with Marla's idea of plants BUT in planter so they can be moved.
    Where will the pool be? I see the trampoline as point of reference.
    Kim
    Sep 2015
    Austin, TX
    144
    Kim
    The pool will go right where the trampoline is. The wall to the left of the pool is the wall that the pool will be "hugging" with the patio in front of the stairs and the porch.
    I wish I would have posted on the forum to help with some of the questions until this point.
    Jan 2015
    Austin, TX
    1,095
    Ok after seeing your existing wall... (I don't know why I didn't see it before)
    I would have a stone patio on the left that blends with the wall. I might even just put them lose with small lines of grass in between.
    Like here:
    Using Flagstone To Build A Patio
    Jul 2012
    Tallahassee, FL
    30,439
    I am not sure I would do the grass due to the kids. You KNOW they will run around the pool and just jump in-CANNON BALL!
    I do like the stone patio as it will slow the kids down some!
    That wall can be a wonderful planting area to enhance the pool and area. Let the kids have one row just for them to pick what they want to plant and take care of there!
    Now something I hope you have already thought about............you have that wall for a reason.......water/rain run off. How does the water move into that area? That is something you will really need to look at and think about. Your patio willl need to be sloped away from the pool and might need deck drains of some sort.
    Your pool has not been built yet.........what other things have you been thinking about? We LOVE to help and spend your money! LOL
    Kim
    Sep 2015
    Austin, TX
    144
    Stone would be great. However, I'm not sure how well it will hold up with the salt (in particular, the stone on that wall is limestone, which is really soft).
    Yeah. You're right about the drainage. We'd have to slope the patio there and probably put in a channel drain.
    One thing that I'm debating right now is whether I can justify the Aquarite Pro with Sense and Dispense. I've heard that the ORM is awful, but that you can disable it. It sounds too good to be true that my chlorine, pH, and polaris are all taking care of the pool just fine (and that I'm just left with skimming, baskets, and checking every now and then). Am I just dreaming here? (Btw, it looks like it's about a $900 swing to upgrade to the pH sense and dispense system). I'm a software engineer so the idea of automation excites me (and it means I'm lazy).
    The other thing that were debating is coping, but I've posted about that some in another thread. So far, we like tan leuder, oklahoma flagstone, quartzite, and some rectangle pavers (like Toscana Blend color).
    Also, for the financially nerdy (like me), here's my anticipated cost breakdown: Pool - Google Sheets
  20. Back To Top    #20
    JamieP's Avatar
    May 2011
    Waxahachie, TX (south of Dallas)
    1,135
    Financially nerdy is good! It's also helpful to see the breakdown for other potential owner builders. Thanks!
    Who is doing your layout? I thought the excavators did that, but I guess I need to look into it more.
    28,000 gallon freeform, Stonescapes Tropics Blue Minipebble with abalone, 3.5' to 8.5' depth. 2 skimmers, 5 returns, dedicated vacuum port, Dolphin Z5 robot. All Pentair equip: EasyTouch 8, IC60 SWG, VS pump, 520 Cartridge Filter, 3 Intellibrites, 2 Color Cascade Bubblers. TurboTwister Slide and 8' Salt System Jump Board. TF-100. My Jan-Mar 2016 build:
    Waxahachie, TX Owner Build - A race to beat the baby!!
