Thread: Vacuum port no suction
    May 2015
    Arlington, TX
    2
    I have a dedicated vacuum suction side port that runs my vacuum. After a storm with a lot of pool debris I noticed the vacuum barely moving. I unplugged the hose from the port and turn all the suction to it and I can barely feel anything. Typically it would be hard to pull my fingers out of it. It is on a valve with the pool bottom center drain. I move the port to that drain and the suction works great. So I'm thinking between the side port and the valve there must be debris (leaves, nuts,branches) clogging the line. I tried cycling the valve back and forth to get enough suction to pull the debris though but nothing changes. Does anyone know how I can clear that line?
    Thanks!
    Andre
    15,000 gallon
    In ground
    48 sq ft Hayward DE filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: Vacuum port no suction
    Set everything to the suction port and shut off the pump. Open up the pump strainer basket and either stick a drain king down it or just wrap a hose with a rag and stuff it down into the inlet and have your helper turn it on full blast. If you're lucky, the water flowing backwards through the line will dislodge whatever is stuck in the pipe.
    May 2015
    Arlington, TX
    2
    Thanks for the reply. Actually it resolved itself after sitting all night. Maybe the debris softened up but when the pump turned on this morning and I turned everything to the vacuum port it was back to full strength. Think I need a leaf canister to catch that stuff before it gets in the pipe. Thanks again for the response and I will try that if I ever need it again.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Seconded on the leaf canister...after I got one last year I'd never vac without it.
    Dolphin E10 Cleaning Robot.
