Thread: Testing Steps in Order
    Nov 2015
    Cabo San Lucas, MX
    2
    I am brand new to this forum and may have missed seeing the answer to this question, but I just wanted to know:
    If I first walk up to a pool with my testkit in hand knowing nothing prior about this pool, what order should I follow to perform a complete set of tests?
    Water looks clear and clean.
    Thanks for your response(s) !
    12,500 gallon concrete irregular shape.
    Sand filter
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Re: Testing Steps in Order
    Hi,
    Welcome to TFP.
    there is no particular order to do the tests. The only one is that has any order to it the the test for Combined Chlorine, it uses the test of the FC, so in that regard, do FC then immediately do CC. Everything else doesnt matter.
    hope this helps,
    Divin Dave,
    Aug 2014
    Northern IL
    4,615
    I do FC/CC within minutes of getting a sample. I recommend doing pH next because those are the three tests that you need to run on a daily/almost daily schedule. That will get you into good habits.
    Then, TA and CH are usually run weekly, do TA first, then CH as that follows Poolmath order. Only do CYA when you have direct sun and about once a month unless there's an issue requiring more frequent testing. So I would say: FC, CC, pH, TA, CH, then CYA.
    JoyfulNoise's Avatar
    May 2015
    13,236
    Do your FC/CC test first. If your FC tests greater than 10ppm, you really can't do the pH test as the results are not accurate when the FC is above 10ppm.
    My typical test routine is -
    FC
    CC
    TA
    pH
    I test CH and CYA no more than twice per month (less frequently in the winter) and I only check salt monthly. I have a titration test for borates but I only check that maybe 4 times per year. With that said, I live in the desert where rainfall is not an issue. If you live in a wetter climate, excess rain water could dilute your pool water and you may need to adjust your testing frequency accordingly.
    Matt
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,575
    I do mine....
    FC
    CC
    PH
    TA
    CH (I do not really do it as I have a vinyl liner)
    CYA
    Here is a link that might help you some.
    I printed this out and have it by my test kit. I no longer need it as it has become second nature to me as it will for you!
    Kim
